Eldorado's Avatar
upper rad hose
can anyone suggest a way of replacing the upper rad hose without draining the coolant system? or is that hose above the water level and not full when the car is cold and off?
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 01-09-2006, 11:12 PM
SoCal Driver's Avatar
Put a pan under the front of the engine. Catch what you can. Not much, a quart or so, will come out.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Old 01-10-2006, 06:42 AM
iobound's Avatar
Send a message via AIM to iobound
When I replaced my upper hoses I minimized the spillage of coolant by using an old plastic gallon milk carton as a funnel. I cut the last inch or two off the bottom of the carton. I put the small end over the plastic drain plug at the bottom of the radiator.
Using a long 12" screwdriver which I put into the open big end I unscrewed the drain plug. When the plug falls out the coolant flows nicely into whatever recepticle you want.
I can't take credit for this idea. It came from www.clarks-garage.com
RPM also stands for Redhat Package Manager
16 year PCA Member
NASA Member
1988 944 NA w/4valve S motor (Daily Driver)
1992 965 Coupe 3.4 Liter, webers, GE60 (Garage Queen)
1998 Volvo V70 Wagon
2002 Barbie Electric Kids Jeep
Old 01-10-2006, 05:03 PM
Eldorado's Avatar
thanks guys..
socal, would you reccomend disconnecting the rad side or the engine side of the hose first to let the liquid drain out??
Kyle
Old 01-10-2006, 05:08 PM
