sasquatch's Avatar
944 to 951 hybrid
My plans on purchasing a tired 951 to merge into my mint 87 944 have changed slightly. I will be taking possesion of a complete 951 engine very soon to install in the 944. I have some questions on compatibilities for those of you in the know.
Wiring: I believe most of the turbo wiring and connectors that are needed in the engine bay and the DME area are already in the 87 944. I just need to install the proper Turbo electronic parts. Someone please enligten me on this if I am wrong.
Clutch: I do not want to change the bell housing and clutch mechanism over to the Turbo unit. With that, can I install a 944 flywheel on the 951 block? Or are they the same already? What am I up againsed here? (Yes, I will be purchasing a good "racing" clutch for the engine.)
Transmission: Already have an S2 transmission installed into the car with a beefed up ring and pinion, but LSD will be on the parts list to get..
This will probably be a year project with the new house taking a good chunk of my time. I want to get the 951 engine completely stripped down and rebuilt before thinking about installing it. But I am excited to get some real HP into my baby.
If anyone can give me any information on this project, like things I need to do or watch out for, let me know. I am a very experienced mechanic with a very well equipped garage.
Please, no bashing. I think we have all heard enough of "just buy a turbo (car)". At least I am refusing to put in a Chebby v-8
Sasquatch
1987 Porsche 944
1974 Porsche 914
"Don't retreat, reload." Sarah Palin
Old 01-10-2006, 04:03 AM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
I am envious. This is pretty much my dream project.
Current Stable: Black 07 Porsche Cayman S: FabSpeed Maxflo Exhaust; VividRacing ECU Tune; IPD Competition Plenum; 997GT3 Throttle Body; De-Snork'd.2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Silver 09 Mini Cooper S ("Mighty Mouse"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. Green 97 Volvo 850 Wagon ("The Viridian Falcon").
Old 01-10-2006, 07:19 AM
SoCal Driver's Avatar
You need the DME, DME harness, knock control module, AFS, throttle switch. Besides the pressure control related items.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-10-2006, 07:36 AM
ae1969's Avatar
Send a message via ICQ to ae1969
Well.........this is exactly what I am presently doing.
If you have a complete engine with all the items that Socal mentions then you should be ok. You will be missing some heatshields. You will also need a 951 exhaust system. You wont have the stock boost guage etc.... but it will work just fine..
The harness will just plug in........ This obviously only works with late model NA's 85/2 and up....
The 951 bellhousings are different. Now the flywheel, pressure plate and NA bellhousing will fit........
Unfortunately I dont think you should do this. The NA pressure plate does not have enough clamping force. THe disc will wear quicker. If I were you I would bite the bullet and get the proper set up. Things I would do......
- You can use the existing flywheel. Just have it lightened...
- New pressure plate (stock or KEP)
- Stock release bearing, needle bearings, pilot bearing.
- 951 Cup disc
- you will need the proper bellhousing.
The S2 tranny is a nice match for a 951.........on a stock/modified 951 it will do fine. You will find traction will be a problem when you raise the boost.... A BIG PROBLEM. LSD is what you want but its not cheap.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 01-10-2006, 08:07 AM
You really need to use the 951 flywheel/clutch/starter ring gear/ and bellhousing setup if you plan to run the 951 DME/KLR engine control. The 951 starter ring gear has more teeth on it than the 944.
And since the ring gear teeth are counted by the engine speed sensor, you would end up with a no start/no run condition if you went with the 944 setup.
Old 01-10-2006, 04:04 PM
meister member
speedracing944's Avatar
sounds like a cool project.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 01-10-2006, 06:41 PM
sasquatch's Avatar
Thanks for all the information. That is why I love this forum.
Sasquatch
1987 Porsche 944
1974 Porsche 914
Old 01-11-2006, 04:38 AM
