bellcw00's Avatar
Send a message via AIM to bellcw00
Question 1983 944 won't start
I have a 1983 944 that was in storage for awhile and now i can't get it to start. I have my local mechanic working on it, but he was told by the local Porsche dealer that there is some sensor or something on the crank that sends a signal for the plugs to fire. Never heard of that but his is my first foreign car.
Any help is greatly appreciated
Carl
Old 01-12-2006, 08:16 AM
They are the reference sensors. That affects the car beign unable to start.. But it could be the fuel pump if its not turning on. Fuel pump relay when that goes bad nothing starts. Could be soem fuses too.
Heres a good place for you and yer mechanic to check out if yer not the do it yerselfer
www.clarks-garage.com
Go under garage shop manuels and under the letter " E " there is a trouble shooter and lots of other info tht will help
Jaime O.
Thank god I crashed or i would never have owned a porsche
83 944 daily driver (clutch and tt time)
85 325e BMW T-boned R.I.P.
Old 01-12-2006, 08:30 AM
SoCal Driver's Avatar
Carl there is a set procedre to check out the Bosch 944 injection/ignition system. Search my past posts as I have repeated it several times.
I would replace the timing belt before going any further. When these cars sit for an appreciable amount of time the belt takes a set and does NOT like to be run around the pulleys again. Breaking the belt will cause at least half the valves to bend.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-12-2006, 08:46 AM
Does it sound normal when starting? Let's hope you didn't lose a timing belt trying to crank it.
Does the tach needle bounce when cranking?
I'd also take a look at a new DME relay, that's cheap insurance. Fresh gas is also a good thing.
1997 BMW 328is
1987 944S- in pieces
Old 01-12-2006, 08:47 AM
What does it mean if the tach needle bounces?
07 Cayman 5spd 141,000 Daily Silver/Chocolate
08 Cayman S 6spd 41,000 Black/Terra-cotta
04 Gallardo Gated 6spd 19k Arctic Grigo/Nero Blue
14 BMW M5 6spd Stick 1 of 577 F10 less than 300 LCI
Old 01-12-2006, 04:20 PM
It is responding to the DME's grounding of the ignition coil. Thus the reference sensor is sensoring. At least while it's cold.
Old 01-12-2006, 04:41 PM
BananaClip's Avatar
Send a message via Yahoo to BananaClip
Is that independant of the DME relay?
keep the dream alive!
1988 944 NA (purple)
Old 01-12-2006, 04:55 PM
No. The first set of contacts in the DME relay have to close to provide power to the DME. This means that the ignition switch is working and providing power to the coil too. The first set of contacts also power the injectors. Like the coil, the DME grounds the injectors to operate them.
Need to check that the fuel pump is running during cranking. This is the second set of contacts in the DME/fuel pump relay.
Other reasons for no start can be disconnected sensors such as the AFS and engine temp sensor. Could also be a bad coil or the coil to dist wire could have broken inside the weather covers at the connectors. A bad fuel pump. Gunked up fuel lines clogging the injectors. Even heard of a golf ball in a fuel tank that would roll around and clog the fuel pump intake.
Old 01-12-2006, 06:54 PM
bellcw00's Avatar
Continuing saga of my 1983 944 not starting
I appreciate your help and advise and I passed the info to my mechanic that I took the car to, and has been sitting there for 4 months now. He is now telling me that it is the computer that is bad and now I need a new one for about $1700.00 Man, i wish i knew more about these cars to try to do it myself. I guess i need to take it to a more specialized repair facility to double check this. Have you heard of any good Porsche repair places around Texas?
Again, thanks for all your help and advise.
Carl
Old 01-30-2006, 04:22 PM
Find another mechanic. Used DME's are around $200. And I bet it's not the DME!
Old 01-30-2006, 04:35 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
Hey bellcw00,
First welcome to the addiction as someone put it. Best advice I can give you...follow SoCal Drivers advice and recommendations. I think he has a sixth sense about problems like these especially on your year of car. I'm pretty busy right now, but if you don't get it soon, let me know...might be time for a road trip.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 01-30-2006, 09:48 PM
rudidelange's Avatar
Get another mechanic - 4 months and then wanting to replace the DME!!!! SolCal has given the best advice. You must also buy the Haynes Manual and read the info on Clarks-Garage's website.
I had similar problems. Once it was once the speed and reference sensors, where they plugged into the engine harness and the second time it was the DME relay. These cars are actually a pleasure to work on, and when you get to know then quite eazy to repair.
1983 944 RHD Original. Uses all my spare cash!
1947 Morris Sold
1972 Benz Sold
1975 Benz Sold
1976 Benz Sold
1977 Benz Sold
Old 01-31-2006, 06:03 AM
For $1700 you could fly me to your car, fix it and fly me back.
Old 01-31-2006, 08:20 AM
Hey bellcw00, You may just want to counter that offer with an offer you can afford. One thing is for sure...you won't find a more knowlegeable person on your car anywhere. If that was my car and I was having problems I couldn't figure out....well, let's just say, SoCal Driver, watch what you sign yourself up for!
Tom
Old 01-31-2006, 12:21 PM
Have DME Relay.
Will Travel!
I did have this idea of getting a motor home and towing my 944 around the US fixing 944's for a living. Wife didn't like the idea.
Old 01-31-2006, 12:34 PM
I guess that means you kept the wife and scrapped the idea?
Tom
Old 01-31-2006, 12:40 PM
Not exactly. Still looking for the motorhome. I'll tell the wife when I find it.
Old 01-31-2006, 01:04 PM
Well all right then, don't forget to add it to your signature line. Maybe you should apply for that job at Pelican! You could then work from your motorhome for Pelican through satellite uplink while you travel to the next 944 problem! Get double paid. More money is always better!
Tom
Old 01-31-2006, 01:08 PM
