Let's go shooting.
Rear hatch seal question
I've a small leak just over the well behind the left hand wheel arch.
Probably just needs the seal replacing - the hatch seems to seat well enough without any play from the locking catches. Anyhow, I lifted a small amount of the seal to see how tight it was (one of the cut ends) and found there was some sort of white tacky sealent underneath. Is this normal - like a thinner version of the tacky black stuff used to help seal the rear lights - or is it likely to be something a previous owner put on to tackle the leak? I wondered if it was necessary to help retain the seal in place.
1983 944 Lux (manual) 2.5 litre 8 valve na and no pas 1991 944 (automatic) 2.7 litre 16 valve na and pas "I have only five words for you: From my cold, dead hands." |
3M weather strip adhesive.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Let's go shooting.
Back from Beyond
I seem to recall the new seals having some adhesive in them. Mine did...
'88 944 Auto - project, kinda '87 944 Auto - died saving my wife '84 944 5SP - crushed under shop roof during snow storm All others GONE! |
Let's go shooting.
