-   -   Maintenance Input From the Group (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/260813-maintenance-input-group.html)
bik517 01-13-2006 01:59 PM
I have a 1986 Porsche 944 with 73,500 miles on it. It has been passed through the family so I have almost all of the maintenance records. It was meticously maintained, but I am trying to figure out what needs to be done now w/out taking it to the dealer. Here are the highlights:
45,107mi - All Belts, Distributor/rotor, Brake Pads
48,324mi - Upgrade to Turbo Motor Mounts
53,074mi - DME control Relay, Thermostat
65,216mi - CV Boots and grease, last coolant flush, last fuel filter (This was in 2001)
From 65,216mi till 73,000mi just oil changes, then I got the car.
Potential List (please add your input):
1. Belts and Rollers
2. Brake Pads
3. Fuel Filter
4. Coolant Flush
5. ?
Thanks for the help,
Bob
SoCal Driver 01-13-2006 02:15 PM
Definately the timing belt and related items. Might look hard at the water pump. If you can wiggle the water pump roller with the timing belt off it should be replaced. Some will just replace it anyway at about your milage.
Time to inspect and repack the wheel bearings. Check the suspension bushings and ball joints.
Then the rest of your list.
How are the tires?
scheistermeiste 01-13-2006 05:40 PM
plugs & wires
bik517 01-13-2006 06:56 PM
The tires are new. Plugs I got. Didn't think of wires, brand preference? Didn't think of wheel bearings, grease preference?
Keep it coming, I am going to keep this car running. Our 1968 912 is at 229,000mi.
Thanks,
Bob
sjfarch 01-13-2006 07:08 PM
It sounds just like the car I got last fall. There is a good maintenance list and lots of other info on clarks-garage.com/shop-manual/maint.
From my to do list I would add brake and transmission fluid change.
