Door problems
My door latch on the driver's side is not working. When I pull the latch from the outside it does not disengage the mech. However the door can be opened from the inside. How should I fix this?
83 944na
Old 01-16-2006, 01:53 PM
you have to remove the door panel and check to see if the rod is still connected to the handle. Then see why the rod came off. It could be as simple as a clip, or the handle can be broken where the rod connects.
Old 01-16-2006, 01:58 PM
Take the outer door handle off, there is no need to remove the door trim panel on early cars, all the work can be done from outside.
Then you can see what has either broken or fallen off. If the handle feels just really stiff, then removing the screw (above the lock on the inner door edge) and spraying a lube in there might solve the problem.
Lubing the door handles and locks is something that should be done frequently anyway.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 01-16-2006, 03:38 PM
