Grog's Avatar
Question 968's, 928's Timing belts. same trouble?
Just woundering if the 968's and 928's have the same 30k timing belts replacement interval? or the same belt breaking trouble?
1972 Dodge Challenger
2011 Raptor
2013 Road King 110th Anniversary
2014 Corvette Z51 stingray
Single after 27 years married.
Old 01-14-2006, 11:08 PM
Ornery Bastard
IIRC the 968 has the same interval. Don't know about the 928, but would assume so. Both are definitely interferance designs and will suffer the same issues as a 944 if a belt does break.
That said, 944's really don't have problems with belts breaking. Provided that service is followed the belts are incredibly reliable. They are no less reliable than the timing belts used on millions of Honda interferance engines. The reason that more is said about them is because if the timing belt breaks on a Honda and it totals the car, it's not too much of a loss; Hondas are plentiful and it's easy to find another car just like it. The 944, on the other hand, is becoming rarer, especially in good condition, and is much more difficult to replace.
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 01-14-2006, 11:45 PM
pokey's Avatar
Send a message via AIM to pokey
928s are non interference, iirc. But should have the same belt sched., but not the danger of bending valves if you go beyond...
Still looking for the right deal on another P-car
1968 BMW 1600 2 liter
1956 Ford F250
1955 BMW R69
1999 Range Rover Callaway #011 of 220 (Yeah, as in Callaway Corvette...)
Old 01-15-2006, 03:45 AM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
Originally posted by AaronM
That said, 944's really don't have problems with belts breaking. Provided that service is followed the belts are incredibly reliable. .
Yes and no. Both Wilk and I changed and retensioned our belts within the recommended interval, and both of us have had belt breaks.
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 01-15-2006, 07:11 AM
Exactly, I've had a couple break for no reason within the mile range and the were correctly tentioned and retentioned with the P9201 tool. WTF?
Old 01-15-2006, 08:15 AM
SoCal Driver's Avatar
Belts were too tight. Take the top section off of the front covers, drive around till the engine is hot (at op temp) and check how tight the belt is. Just might be a good idea to tension the timing belt on a hot engine and not a cold engine.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-15-2006, 08:46 AM
Writer/Teacher
CJFusco's Avatar
Well, that just goes to show you - the best way to ensure against problems occurring is correct maintenance and service... but that is just the best way to ensure against it, not to stop it completely. These things happen, just imagine how much more often they would happen if we DIDN'T replace and retension within recommended intervals.
Old 01-15-2006, 08:48 AM
Eldorado's Avatar
exactly..
with moving parts, any number of variables can affect belt life. And sometimes it just boils down to the manufacture process - everyone spits out a bad product once in a while.
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 01-15-2006, 09:56 AM
gadgit's Avatar
SoCal, I'm sure you meant the other way round. Tension it when its cold not hot?
If you did it when its hot, it will get tighter when cold and more likely to break if been in a freezing garage all night when started!
Eh!
Old 01-15-2006, 10:22 AM
livewirevoodoo's Avatar
Eh!
Wouldnt it get a little looser when cold?
If i recall correctly from high school physics class, heat causes expansion and cold retraction.
Thats why you run the pickle jar under hot water so the metal cap expands and you can open it.
''87 944na 85k
C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946
'94 Oldsmobile 88 Royale (winter beater)
Its not what you drive, its what drives you.
Old 01-15-2006, 03:06 PM
Ornery Bastard
Eh!
It's not the belt expanding, it's the engine. The pullies get farther apart when the engine is hot because the aluminum expands a good bit. So even though the belt itself expands a little when it heats up, the engine expands much more (relative to the belt) and therefore the belt is significantly tighter when the engine is hot than it is when the engine is cold.
Old 01-15-2006, 03:26 PM
gadgit's Avatar
Got it!!
thanks for that>
gadgit.
Old 01-16-2006, 03:38 AM
Cars & Coffee Killer
legion's Avatar
Some 928s are interference, some are not. It depends on the year and model (S3, GTS, etc.).
5 liters of VVT fury now
-Chris
Old 01-16-2006, 05:03 AM
adrian jaye's Avatar
944 s2 engine = 1/2 928 engine ergo, interferance
re: hot and cold.
OEM's and Indies check tension with engine cold
(at least in the UK they do)
The fear of God is the begining of wisdom <><
NotJustPorsche
Subscribe: notjustporsche-subscribe@yahoogroups.com
Old 01-16-2006, 06:30 AM
Ornery Bastard
Wrong. While the 944 engine is based on half the 928 engine, it is not exactly that. The 928 engine was, first of all, only 4.5 litres when the 944 engine first came out. 2.5 litres is more than half of 4.5 litres. Also, only a few parts are actually interchangeable between the engines and compression ratios differ between the two.
Old 01-16-2006, 10:34 AM
