Send a message via AIM to TurboFoFo
Need to raise my car
Hey guys, I am wanting to raise the height of my car. Maybe about half an inch in the front and 1/2 - 3/4 in the rear. My new wheels and tires slightly rub on the fenders when too much weight is distributed to them by sharp turns or a full tank of gas.
What's the best way of doing this? I am guessing adjustable coil-overs would do the trick right? What are some good options? Thanks all.
Alex
PCA Member
86 951 Blk/Blk
Guru Chips, Momo MonteCarlo Wheel, Kinesis 17" SuperCups
Old 01-20-2006, 09:47 PM
SoCal Driver's Avatar
Options? Get smaller tires.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-20-2006, 09:57 PM
hahahah yeah that's not going to be an option for me
PCA Member
86 951 Blk/Blk
Old 01-20-2006, 10:25 PM
pokey's Avatar
Send a message via AIM to pokey
I heard you got some baaadaaasssss dub 22s on dat bisnatch. just throw some airbags unda it and is awight...
Still looking for the right deal on another P-car
1968 BMW 1600 2 liter
1956 Ford F250
1955 BMW R69
1999 Range Rover Callaway #011 of 220 (Yeah, as in Callaway Corvette...)
Old 01-21-2006, 02:01 AM
PCA Member
86 951 Blk/Blk
Old 01-21-2006, 07:33 AM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
how large are the wheels/tires?
Current Stable: Black 07 Porsche Cayman S: FabSpeed Maxflo Exhaust; VividRacing ECU Tune; IPD Competition Plenum; 997GT3 Throttle Body; De-Snork'd.2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Silver 09 Mini Cooper S ("Mighty Mouse"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. Green 97 Volvo 850 Wagon ("The Viridian Falcon").
Old 01-21-2006, 07:37 AM
That Guy
Techno Duck's Avatar
Adjustable coil overs would work in the front, but you are looking at minimum $200 for the adjustable spring perches, not to mention new springs to work with those perches and new struts...because i doubt you want to go through all that trouble of replacing the suspension and needed an allignment afterwards (another $100 about) just to put in old struts. That alone is apporaching a set of tires.
The rear you can get about .5 - inch of lift i believe using the camber eccentric trick. I know for a fact you can get that in a drop (did it myself yesterday), so i would think you can get in the other direction also.
And just how big are the wheels and tires you are running?
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 01-21-2006, 08:30 AM
Writer/Teacher
CJFusco's Avatar
it seems rather silly, imho, to raise the center of gravity in a sports car just because your tires rub... what do you have, 18s? I would personally just go to smaller wheels (or lower-profile tires) than make your 944 higher...
Old 01-21-2006, 09:33 AM
Non Compos Mentis
Let us know, then we can give you an intelligent response.
Old 01-21-2006, 11:07 AM
fronts are 17x8 55 mm offset wrapped in Pirelli P-Zero Nero M+S 245/45/17
backs are 17x10 60 mm offset wrapped in Pirelli P-Zero Nero M+S 275/40/17
car has 1.5" spacers all around. 17" Kinesis SuperCups
PCA Member
86 951 Blk/Blk
Old 01-21-2006, 12:52 PM
Writer/Teacher
CJFusco's Avatar
I'm thinking they probably shouldn't rub. Have you already lowered the car?
Old 01-21-2006, 12:58 PM
that what i thought too, not really a reason fo rit to rub but as far as I know the car has not been lowered. i could be wrong though. I suppose i'll ahve to check it out and let you know
PCA Member
86 951 Blk/Blk
Old 01-21-2006, 01:35 PM
Non Compos Mentis
-Rubbing inside or outside?
-How is your alignment? Time for less camber?
-How old are your rubber bushings? Soft enough for the suspension to get sloppy?
By raising the car with alignment settings, you may just allow for a bit more suspension travel before the rubbing begins.
Old 01-21-2006, 03:01 PM
Will work for parts
944 boy's Avatar
Send a message via AIM to 944 boy
Im not surprised that they rub. 245/275 are quite wide. 265's on my car is as wide as I can go with no rub. I have a friend with an 85 that 255's rub. You can increase camber which will help outside rub, and also as others mentioned, replacing bushings will keep the suspension from deflecting as much. Have you looked into having the fenders rolled any?
'88 944 240,100 miles -race car
'05 Boxster 110,000 - Daily Driver
'74 911 Targa - long term project
Old 01-21-2006, 03:05 PM
Sam Grant's Avatar
1" spacers?
1995 M3 LTW
Old 01-21-2006, 03:12 PM
Writer/Teacher
CJFusco's Avatar
also, what size is the sidewall. can also be a factor...
and this is just a thought, but would thicker swaybars prevent this a little bit (less body roll = less lean from side to side)?
Old 01-22-2006, 07:42 PM
meister member
speedracing944's Avatar
What about removing the spacers, taking them to machine shop to have them slimmed down a bit.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 01-22-2006, 08:03 PM
gohan's Avatar
$300 from eastwood.
Old 01-23-2006, 12:04 PM
