Send a message via AIM to fierochris Send a message via Yahoo to fierochris
sway bar
I was tinkering with my 944 today trying to reconnect the sway bar ends back into the end links but cant seem be able to muscle
them back in. any tips?
71' 911T Targa, current toy.
86.5 928s traded for new 911
71 911 Targa w/ gas burners, PMO's, *sold*
Lamborghini diablo replica w/ 350 V8
85.5' 944 n/a euro ( gave to dad )
87 fiero cp. candy blue, chrome 16's
90' DSM 24psi. 18G fmic,
82' benz 300sd turbo, intercooled.
73' Karmann Ghia cab. sold
04' Standard 250s ox, euro bb 28/10 gearing, odyssey, profile, 29lbs,
check out www.vintagevwcars.com
wanted: 914, 944, 928 project
Old 02-02-2006, 07:09 PM
Re: sway bar
also what could have caused them to pop out of the endlinks?
Old 02-02-2006, 07:10 PM
GostRidr's Avatar
Hey Chris,
endlinks? is that where they connect to the control arm? are you having a problem with getting the bolts to line up or did your sway bar come out of the vertical bushings? If your bushings are old they may not hold it in place.
peter
1991 944S2 Cab, Crystal Silver Metallic "Platinum Banshee"
1987 944S Alpine White, Ice Shark Lights "Desert Ghost"
2015 Charger R/T Road & Track
Old 02-02-2006, 09:43 PM
it came out of the bushings on both sides
Old 02-02-2006, 09:46 PM
GostRidr's Avatar
Mine slides in and out at will but only up to the wider diameter of the bar. Your best bet is to remove the whole bar and bracket from the car (two bolts on the bracket frame on each side). This will allow you to slide the ends back on and reattach.
peter
Old 02-02-2006, 10:13 PM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
If you're having trouble getting them on the bushings, I recommend taking the bushing housing off the car and using some sort of vice to get them back in. They are not suppsed to be loose fits.
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 02-03-2006, 06:27 AM
