Thumbs down creaking steering
bought my 944S2 last Jan and after 5 weeks it started running rough. which after investigation turned into a total engine re-build.
cars now running like new (well it is really) Jan comes around again and its just starting creaking when the steering wheels
turned to full lock..
ggrrr has this car got a fobia of spring
Old 01-25-2006, 01:38 PM
PhillysMostWntd's Avatar
Send a message via AIM to PhillysMostWntd
my car does this as well in cold weather, IRC this is normal
anyone else?
1984 Porsche 944 - down for the count, may be rebuilt
1999 Civic ex coupe - Turbocharged fun/Daily Driver
Old 01-25-2006, 02:04 PM
Let's go shooting.
Dark Skies's Avatar
Re: creaking steering
Could be your PAS hydraulic fluid is low. As I recall (long time since I did it) you check the level on the dipstick when on full lock with the engine running, as this puts the maximum load on the system.
Topping up fixed this problem for me (caused by a slight weep at the reservoir pipe).
1983 944 Lux (manual) 2.5 litre 8 valve na and no pas
1991 944 (automatic) 2.7 litre 16 valve na and pas
"I have only five words for you: From my cold, dead hands."
Old 01-25-2006, 03:06 PM
BananaClip's Avatar
Send a message via Yahoo to BananaClip
mine did this in the cold until i finally fixed the ps leak, which happened to exist because one of the non-pressure hoses had dry-rotted. you could rip it with your fingers it was so bad. replaced the hose, bled the system, no more leak, no more groan.
bleed it and make sure you don't have any leaks i guess
keep the dream alive!
1988 944 NA (purple)
Old 01-25-2006, 04:59 PM
