Dtchy's Avatar
Please don't tell me this is true...
Hi all,
I have an 86 na and my steel manifolds are cracked. I recently purchased the cast iron ones from the earlier models, since they seem to be stronger. They're currently being ceramic coated...
I just read some info that they shouldn't fit the later models...Did I just waste $100 plus ????
Horsepower is how fast you hit the wall...Torque is how far you take the wall with you...
1994 BMW 325is M-Technic
1986 Porsche 944 N/A
Old 01-22-2006, 10:48 PM
It's not true. The cast iron exhaust manifolds (that typically last the life of the car) will fit any 8v na 944 from 1982 to 1988.
Good luck, George Beuselinck
www.944ecology.com
Porsche Deconstructor (tm)
We buy 944s and sell 944 parts (845-379-1944)
We rebuild torque tubes and instrument clusters for 944/968/928
Old 01-23-2006, 01:00 AM
Dtchy's Avatar
PPFFFFFFEEEEWWWWWWWWW!
Thanks for the info man...
Old 01-23-2006, 07:13 AM
You can, and we do, weld the steel ones. They only tend to need welding once in a lifetime.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 01-23-2006, 07:54 AM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
Dtchy....I'm not sure they will fit yours....so AFTER you get them looking perfect, send them on down to me and let me see if they fit mine! ;-)
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 01-23-2006, 08:03 AM
Dtchy's Avatar
Hehehe Razor...You wish!
I can send you a picture though...
Man, I was sweating bullets for a second.
Old 01-23-2006, 09:02 AM
It was worth a shot! I would have been sweating bullets too. Yep, I'd like to see the pictures after they are installed. Let me know how difficult that was. I think my 87 has a small exhaust leak but I haven't started to look and see yet. Can you or Britwrench shed some light on where they typically break at so I can start looking there? Britwrench, do you typically weld them on the car or do you take them off to repair them?
Tom
Old 01-23-2006, 09:55 AM
Dtchy's Avatar
I'll post pictures of my cracked ones and the refinished set. I'm gonna have my steel set weld and keep them as a spare set. I probably won't get a whole lot of money out of those anyway.
I think mine is cracked on the #1 cylinder, but I'm not sure. The sounds is definitely bugging me...Like my car is farting all the time... At least she smells good...
Old 01-23-2006, 11:57 AM
ae1969's Avatar
Send a message via ICQ to ae1969
I used the steel ones on my NA as well........... Just make sure your motor mounts are in good shape. The vibrations are not good for the headers/fuel rail etc....
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 01-23-2006, 12:24 PM
They break in the "y" join for 1 - 4 cylinders. We take them off, cut open the cover piece and weld the crack, then reweld the cover. Have an old 944 head as a jig.
Old 01-23-2006, 12:25 PM
If I don't have an old head, is there any way to do this?
Tom
Old 01-23-2006, 12:38 PM
Carefully clamp it to the bench. Measure the exhaust stud spacing and use a cardboard template as a guide.
Old 01-23-2006, 03:51 PM
SoCal Driver's Avatar
While you have the steel maifolds off look down the 2-3 Y at the splice. The set I have is half blocked by the inserted tubing. Really poor job of splicing. Might dig them out and take a picture now that I have a digital camera.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-24-2006, 08:06 AM
That's a good tip. I'll check into that if mine are cracked. Did you cut them apart and reweld them or get different ones?
Tom
Old 01-24-2006, 10:02 AM
Dtchy's Avatar
If I can jump in...I decided to go with the cast iron ones. They hardly ever crack. I'm having them coated to expand the lifespan, so I never have to worry about taking them off again...As I said, I keep the other set as a spare.
But from what I've heard they usually tend to last a long time when they're rewelded.
Old 01-24-2006, 10:54 AM
