Electrical Problem Fuse box
Here's an easy one.
I have a 1985/2 -944 which the head lights don't work. I lifted the central electric box up to look underneath it. The central electric box houses the fuses and relays.
In the middle of the box a connection was loose. Last week I fooled around under the box and must have disturbed this connection.
I can't seem to get this connector back in to its rightful spot.
How do these connectors snap in?? What is the secret? Do I have to take the side holding bars off to get this connector back in?
Thanks for the help.
1985/2 - 944 Good ten foot car
Old 01-26-2006, 03:32 PM
There is a sliding latch bar along the middle of the fusebox. Apparently your connector popped off in spite of this bar. You would have to slide the bar to the release position to re-insert the connector without all the others coming out and then re-latch.
Gene
____________
'86 944 NA
'88 Citroën 2CV
Old 01-26-2006, 07:02 PM
SoCal Driver's Avatar
Disconnect the battery first.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-26-2006, 07:09 PM
