-   -   Dohc ? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/262584-dohc.html)
924Sracer 01-23-2006 07:11 PM
Dohc ?
I have been searching for specs on the 16v heads. I would like to know the differences between the 3.0 and the 2.5 944 heads. Are the 928 DOHC heads a direct bolt on? And if so what are the specs on it.
Any comment that points me in the right direction would help.
Jason
fast924S 01-24-2006 07:21 PM
I would check over at rennlist, A couple weeks ago they had a good thread with the same questions being asked.
924Sracer 01-25-2006 09:04 AM
I'll have to look around a little harder. From what I have found the intake and exhaust ports seem to be different between every model except the S2 and 968.
aribop 01-25-2006 10:25 AM
water passage on the front of the head going into the block is different between 2.5 and 3.0. The 2.5 one is inset towards the back of the head like a regular 2.5 head. 3.0 is even with front of block like the 2.7 motor.
