weird problem
Today I was driving and my car started going from the point of almost stalling to like 3k while the car is idling and the car feels like its chugging at low rpms. What could be wrong? I just started the car after sitting a while and it seems ok. The car was idling a little high yesterday also. Im guessing the iac is going?
vacuum leak(s), dirty injectors, bad fuel, boost leak(s)...
well i got to look at it today and the little hiss from under the manifold got worse. So I pulled the manifold today and found that every clamp was loose:eek: Later im gonna order the venturi delete hoses and top quality clamps
The housing thats under the cv that has a vacume switch I noticed is leaking. What do you call that part so I can get a gasket for it?
| All times are GMT -8. The time now is 06:15 AM. |
