Gon fix it with me hammer
weird misfires
Hi,
i'm running the MSD 6a ,PN6200 with a Bosch blue coil on my 924 recently the car develloped some weird misfiring usually starts off with the tach needle going wild, blipping to 6K rpm when the engine is probably only doing between 2K and 4K note , the tach needle starts blipping before the actual misfires and it's attached to the tach output on the MSD box once it starts acting up for real , it seems to be only onder load lot's of backfires in the exhaust, and the whole car bucks coast a bit ,while i rev the engine with the clutch in or i try revving under load it seems to happen less often if i keep the revs low ( 2000-2500 rpm) , which ain't that practical as it means i'm almost lugging the 4 banger constantly i'm not sure if either makes one bit of difference the problem sometimes goes away by itself only to return minutes later at any time when it does happen , the car will idle if left to idle if it goes away , the tach needle behaves normal again i first suspected the plug wires ,as these were the old stock wires, Beru's had those replaced with Magnecors, but the problem persists dizzy cap, rotor, plugs are all less then 4000 miles and they look fine tried cleaning all of them , didn't help one bit the tach blipping makes me think the MSD might be the problem as the tach is fed directly from the box has anyone seen this before?? anything else i could try or check? does anyone know if i can wire up the blue coil , and not use the MSD box if only as a test, or do i need a normal coil for that if so , how do i wire things up? don't have a factory manual or haynes around... thanks in advance, Stijn
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
when I had this problem on my stock 924 the culprit was always a carbon track inside the cap. I later (after 6 or 7 caps ) found that my timing was set about 3 degrees or so too far advanced.
Worth a check. Good luck Rob |
same exact symptoms? tach going mental and so on ??
i checked the cap , there was some carbon , but very little scraped off the contacts , didn't really help i'll see if i can score a fresh one for a try...
the carbon tracking will look kind of like a really thin pencil line. Hard to find. I was having this happen every 250miles or so. The carbon will run down the inside of the cap to the step where it meets the distributor.
put a new cap on it and poof my symptoms dissappeared..... for a while. I got to the point that i kept a couple of new caps in the car. Rob |
Yes tach would freak out
i'll definately give this a go, got a day off on thursday to work on my cars , the both of them...
just gave the dizzy a wipe with my hands. bit to early to call it full on success. but it didn't act up as much on my short drive home
i'll slap a new one on thursday... that'll probably it won't be bored thursday though, got a new gremlin to sort out headlights are stuck in high beam mode, and the headlights are out at the same time, only had the lower fog lights to work with... something funky with the relay panel , if i push it while messing with the relay , the engine kills.. always leave something unfixed they say... ![]() big thanks for the tip about the carbon thing i thought that the only thing to check on hte cap was the contacts...
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 Last edited by svandamme; 01-31-2006 at 11:22 AM.. |
the fusebox is a bastard child. It is made up of copper or brass traces that are riveted together with steel rivets. any moisture and dissimilar corrosion sets in aggravated by the current passing through the juncture. I priced a NEW fusebox here at the Porsche dealer in Dallas for around $80 last summer.
You can either remove yours crack it open drill out the rivets clean the connections then solder/braze the bars back in place, or buy a new one (then fix the old one for a spare) . Rob |
Hey Rob, That's a good tip to remember. Any particular year that tends to happen to? What year is yours?
Tom 1990 944S2 Cabriolet 2002 Chevy Silverado 2500HD 2003 Maroon Ford F350 dually |
Politically Incorrect
You should have read the MSD 6A manual before you installed it. You CANNOT use the stock BERU wires for several reasons. Most importantly, they are definitely not rated for the voltage the 6A can produce. MSD requires that wound resistive wires are to be used. The stock BERU wires are not resistive and actually look like CATV coax cable if you were to cut one open. The spark plug wire contacts, as BERU calls them, DO have a resistor in each end but it's not the same as wound resistive wires. The stock wires will also emit excessive EMI, when used with the 6A, that can wreak havoc with your DME (which your '77 924 does not have) and cause radio static.
If you do bypass the 6A for a test MAKE SURE you use an additional current limiting resistor (0.8 ohms) in the + side of the coil circuit or you will eventually cook the resistor embedded in the rotor. (AMHIK) I have a MSD 6A, MSD Blaster II coil and Magnecor wires in my '87 946 and am completely satisfied with the performance of this combination. On another note, you can widen the spark plug gap to take full advantage of the of the 6A's potential. Wider plug gap means higher voltage (hotter spark) before the coil voltage jumps that gap, but not too wide of a gap that could cause cabon tracking problems and running problems. Experiment.
Edek '87 924S '91 535i |
i'll second that and since my car is long over due for new cabin seals , with bit to much wetness inside... i'm sure that'll be it it's my own fault really , refused to do any preemptive work on nthe 924 untill the 911 was running reasonable again...
mine was a 78 924 na
yes was I do not own it any more, but sold it to a friend, so he calls me any time there is a problem for advice. I still lurk here regularly because I will most likely own another. I do miss that car, but had to sell it because I had too many cars at the time and Wifey tolerated it for quite some time before it became a problem. When you move and it takes longer to move the cars and car stuff and tools, than it takes to move an entire 3300sqft house full of her crap (and 4 kid's stuff) there might be a problem. Rob |
What would that problem be?
Well, it isn't a problem for me, I now have a detached 16X25 shop,
but you see when I sold my 280zx because parts were starting to add up quick, I kind of slipped into the aircooled addiction, next thing you know I have a convertible bug (wife claimed that one), bought a ghia (my DD) then the phone call came in, guy down the street that I knew had a bug wanted to get rid of some stuff...................... I wandered into his yard and behind his shop was 66 bug 68 bug 69 ghia 68 notchback so I BOUGHT THEM ALL (but honey the were on sale-buy three get one free) good deal and came with even more crap I mean "spare parts" anyway then someone called with a free car (good title-runs like crap come get it 1988 buck park avenue) so I took the Suburban and towed that one home too. then local code enforcement came around so sold the buick sold the 68 bug sold the 924 am in the middle of selling the 66 bug keep the driveables in the driveway still got more crap "spare parts" for more VW's than I know what to do with I have fenders and bumpers and decklids in the attic and literally 5 gallon buckets of carbs and oil coolers and engines and (honey, some of this stuff is very hard to find now) so I try to be good then I get the call today, come get this buimper out of my garage, I know the chrome is still good, but I have no room. So I hope the attic is not near the weight limit yet, it will have more tonight Rob |
sounds like you got a good thing going there
i need to park my 911 60 km's away cause housing is so expensive in R'dam, and none have proper garages in em hence the slow progress.. i need to plan going to the garage , making sure somebody is there, only saturdays on weekends, or days taken off during the week...
I have a friend that might be looking for a running engine for a bug if you have an extra. His budget is very limited so it would have to be an inexpensive engine.
have him go to the dallasaircoolers.com website and post in the houston aircoolers and aircooled parts wanted section, that will be a whole lot closer to him.
Rob |
I'll do that, thanks Rob
