PhillysMostWntd's Avatar
Send a message via AIM to PhillysMostWntd
Fuel Injector ?'s... PICS
ok so as you know im rebuilding and freshening up my engine, trying to get all the problems sorted out.. anyways i got around to the injectors, 1 injector boot was cracked, removed all 4 injectors.. 2 boots were destroyed during removal, the other 2 were fairly damaged, the plastic was sooo brittle. anyways, i decided that i was going to have them cleaned, and whilst i do that ill change the o-ring seals and injector boots.
i got the injector boots from autozone.. not my first choice but i'll live with it.. i think, the brand of the part is "GP Sorensen" anyone used these? they seem just fine to me. anyways ive provided a pic below,
http://x2.putfile.com/2/3300193679.jpg
the top left corner is the new o-ring seal, top right is the injector; to show to top o-ring seal, bottom left is the old o-ring, bottom right is a plastic washer sort of thing,
few questions.
1. the top and bottom o-ring seal are the same correct?
2. the plastic washer, do i reuse the old ones?
3. cant really see in this pic, but there is a metal clip on the injectors, i noticed they are only on 2 of my injectors, they dont seem to be serving a purpose, what are they for?
this is a big post for a simple question, just with all the stories ive heard of engine fires i dont want to mess around with this, id like to do it right. engine fire = bad.
1984 Porsche 944 - down for the count, may be rebuilt
1999 Civic ex coupe - Turbocharged fun/Daily Driver
Old 02-02-2006, 10:25 PM
SoCal Driver's Avatar
Metal clip? At the top? It's to hold the injector to the fuel rail for handling. The four bolts to the head (cam cover) hold the whole assembly to the engine.
The most important o-ring is the one at the fuel rail. If this is pinched it will squirt (not leak) lots of fuel. The bottom one will just be a vacuum leak that is next to impossible to find.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 02-02-2006, 10:35 PM
here is a pic of the metal clip, its about 1/4 down from the top of the injector, is this what your talking about?
"The bottom one will just be a vacuum leak that is next to impossible to find."
the bottom o-ring seal or the injector boot?
Old 02-02-2006, 10:55 PM
The injector cap is there to help the spray pattern. The end of the pintle is supposed to have a small flat on it. This fans the fuel out into a cone. The cap/hat controls the outside of that cone.
The o-ring at the discharge end fits into the counter bore in the intake manifold -- a high vacuum area. The o-ring at the tip fits into the stamped steel cup on the fuel rail. This has 30 to 50 psi of fuel pressure when the engine is running. AFAIK both o-rings are the same.
If anything is important it's that the injectors filter screen is clean, there is a flat on the pintle and that all of the caps are the same. You can back flush the injector with a foot or two of fuel hose pushed over the discharge end tip, fill it with solvent and hit it with a blast of shop air that forces the solvent backwards through the injector. This will blow most of the crud out of the screen filter on the intake side.
Old 02-03-2006, 10:32 AM
Item 5 in this illustration is the retaining clip.
Old 02-03-2006, 10:39 AM
Socal, thanks for your help, i should be finishing this up over the weekend.
Old 02-03-2006, 10:40 AM
iobound's Avatar
Send a message via AIM to iobound
One tip when you put the rail back in. Dab some transmission fluid on the top o-ring of the injector. This keeps the o-ring from pinching or ripping when you press the fuel rail down onto the injector. Ask me how I know :-)
RPM also stands for Redhat Package Manager
16 year PCA Member
NASA Member
1988 944 NA w/4valve S motor (Daily Driver)
1992 965 Coupe 3.4 Liter, webers, GE60 (Garage Queen)
1998 Volvo V70 Wagon
2002 Barbie Electric Kids Jeep
Old 02-03-2006, 11:50 AM
yes that is exactly it, is it a no-no if i dont have those on 2 of the injectors?
in other words.. do i need them?
Old 02-03-2006, 03:23 PM
how do you know..? i have a feeling its something along the lines of "engine fire", transmission fluid then?? what dot rating? lol a guy recommended to put spark plug grease on the top o-ring seal? any thoughts on that?
Socal - just a random question of something ive wanted to know recently, what is item #16 in that picture??
Old 02-03-2006, 03:27 PM
A/C idle control valve. Opens when the compressor kicks in to keep the idle close to 900 rpm.
Old 02-03-2006, 07:54 PM
