Send a message via AIM to fierochris Send a message via Yahoo to fierochris
ebay purchase
Hi. im currently bidding on a dme wiring harness from a 83 944.
A pelican member told be that i may not be able to use this harness since my car is a late 85.5 and that i would have to purchase a later harness. is this true?
note that the only part of the harness i need is the injectior harness's
71' 911T Targa, current toy.
86.5 928s traded for new 911
71 911 Targa w/ gas burners, PMO's, *sold*
Lamborghini diablo replica w/ 350 V8
85.5' 944 n/a euro ( gave to dad )
87 fiero cp. candy blue, chrome 16's
90' DSM 24psi. 18G fmic,
82' benz 300sd turbo, intercooled.
73' Karmann Ghia cab. sold
04' Standard 250s ox, euro bb 28/10 gearing, odyssey, profile, 29lbs,
check out www.vintagevwcars.com
wanted: 914, 944, 928 project
Old 02-02-2006, 07:07 PM
SoCal Driver's Avatar
Same wiring for the injectors. Difference between the two harnesses is how the idle valve is hooked up. What makes you think you need the injector wiring?
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 02-02-2006, 07:35 PM
mine was smashed during head reintallation after a timing belt got stupid
on the last owner (operation cougar)
Old 02-02-2006, 07:39 PM
Politically Incorrect
onZedge's Avatar
Check out Lindsey Racing. Injector harness for 944 N/A is 140 bucks. You even get to pick the color!!
(yes, I AM fishing for a discount for that plug!!)
Edek
'87 924S
'91 535i
Old 02-02-2006, 08:41 PM
ive looked at it but for now i just want to get my 944 running
Old 02-02-2006, 08:50 PM
You can cut into the harness sheathing at the firewall cross over and splice the replacement harness in. I've done it before. How far back is the current harness damaged?
Old 02-02-2006, 09:29 PM
If you need a harness, I've got one from an early 944. Downside - I'm in Canada. PM me if interested.
Then again, maybe one off e-bay for ten bucks might be the way to go...
'84 944 - new-to-me DD!
'83 944 - looks like ass, runs like horse - in primer.
'82 931 - roadster project - forever incomplete.
'80 924 - spouse's yellowjacket.
Some wrecks and a 924 racer.
Old 02-02-2006, 09:36 PM
there is a connector that ian (operationcoagar) tried connecting the bare
injector wires into right between the rear of the intake and the firewall
that where the damage stops. so from that connector to the injectors
is what i need
Old 02-02-2006, 09:39 PM
The eBay one may have a decent set of sensor cables too! These have to be run from the sensors directly to the DME connector. However the 83 has the DME under the steering column so they may be a bit short for the later models that have the DME under the passenger side foot board. Guess you could sell them and recoup some of your expenses.
Old 02-02-2006, 09:40 PM
Then again, maybe one off e-bay for ten bucks might be the way to go... [/B][/QUOTE]
weres one for ten dollars? SOLD SOLD SOLD!
sorry for yelling guys but thats allmost too good to be true
Old 02-02-2006, 09:41 PM
would you be interested in the remains for you 83?
Old 02-02-2006, 09:42 PM
