85 na h2o pump
anybody replaced there non-turbo water pump
with a rebuilt one. i would like to just remove and replace
the non-turbo original one in my early 85 944?the car is a
street car no upgrades just stock.i know a lot have upgraded
to the turbo pump but if a rebuilt na pump has worked for you let me know.
vendors to recommend??
Old 02-12-2006, 08:37 AM
SoCal Driver's Avatar
Only one type of pump available -- turbo. You might find a rebuilt rebuilt that has the non-turbo casting but I doubt it. Besides the turbo pump must add at least 10 HP!
You will have to replace the timing and balance belts too.
If you cut the back cover a certain way you can leave the balance shaft and crank pulleys on. I would reseal them if they are leaking.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 02-12-2006, 09:05 AM
There are three rebuilt types of pump available.
1. Original early without the block-off plate or timing belt guide.
2. Earlyish with the timing belt guide, without the block off plate.
3. Fit's everything with the block off plate and timing belt guide.
These are for all 2.5 NA engines, the #3 one fits the 944 Turbo as well.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 02-12-2006, 11:21 PM
