Eli K's Avatar
Tire sizes for 88 924S
Has anyone tried running 225-55-15s all around on their 924S? I currently have 225-45-15s but may go to 55's if someone can confirm fitment...
Old 02-08-2006, 08:01 AM
MAGA
Tim Hancock's Avatar
Are your 225-45-15s on stock 6-15 phone dials, if so how do they look? I was about to buy 205 60 15s to replace the worn out stock sized 195 65 15s on my daughters '87 924S. Do the 225s bulge out to much on the stock wheel?
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 02-08-2006, 09:22 AM
Eli K's Avatar
THe tires look great. I'm running 15x7s all around.
Old 02-08-2006, 10:02 AM
I'm running 225/50-15s on 15x7, but I have the M030 suspension, which has a narrow perch. I think you will likely have some rubbing on the spring, driven at the limit, with the stock suspension.
Väino
'93 968 Coupe, 42K Black/Black
'86 944 Turbo, 24K miles and holding
'87 924S, Gone!
http://www.944t.com
Old 02-08-2006, 10:14 AM
Eli K,
I'm running 15x7 phone dials (52.3 offset) with 225/50-15 Kumho V710s as my AX set up. With 1 degree negative front camber, they are close, but they don't rub.
The section width for my tire (from TireRack specs) is 9.3". The 225/45/15 Hoosiers from the same site are 9.8" That would be pushing it. The spec 944 guys run with a skinny spacer in the front for 924S's for good negative camber and 225/50/15's.
I'd like to hear how you make out.
Good luck.
924SBob (the other one)
87 924S
Old 02-08-2006, 02:04 PM
924s 88
Eli 's car has mo3o plus smaller springs 2/1/4 also spring perches reduced in diameter by race shop ,and runs 1.5 deg neg camber in front it started as stock mo3o car and has also had chamber plates added
Old 02-08-2006, 09:32 PM
With 2.25 in springs and the perch trimmed, there should be no problem. The camber plates can only help, I think.
Old 02-10-2006, 12:52 PM
Eli K's Avatar
Thanks Jesse, and all. The shop I was ordering the tires from ended up having my current size in stock, ok for now, but good to know in a pinch.
Old 02-10-2006, 07:22 PM
Verruckt's Avatar
I had 225/45R16 on a 7" rim on the front of my 924S. No rubbing. It looked as if I could run a 225/50R16 as well in a pinch. What kind of tires did you buy?
The crashes people remember, but drivers remember the near misses. – Mario Andretti
1991 944S2 Rally #951 Rally-America.com
Old 02-13-2006, 09:19 AM
