-   -   Reverse glow guages. (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/266768-reverse-glow-guages.html)
Gear Dog 02-16-2006 05:46 AM
I installed a set last weekend and they look great.
Took me all of like 2 hours to install, but that was because I painted the housing. I figured since I had it apart I would put a fresh coat of black paint. I primed it white first just to see what the whole cluster looked like the same color. I wasn't crazy about it so it went back to black.
The install was pretty easy just pinch the needles off and put the faces on. routing the wires took a little finessing but again pretty easy. What I did find interesting was that it came with it's own on/off switch. When I assembled everything I turned the lights on the original lights illuminated but no reverse glow. So I hit the switch and they came on. I tried shorting the switch so that it stays on but that didn't work either. I kinda like it though because now I have two options. I'll post some pic's as soon as I get my new lens for the cluster.
fierochris 02-16-2006 07:44 AM
what did you hook the power supply up to?
Gear Dog 02-16-2006 11:27 AM
There is a light for the center vents that I tapped into. The light was blown anyway so I just pulled it out.
Z-man 02-16-2006 11:31 AM
More info on this, please. Pics, sources...etc. would be great!
Thanks,
-Z.
Gear Dog 02-16-2006 06:39 PM
here are a few pic's of the guages out of the car.
http://i10.photobucket.com/albums/a1...7/DSC00463.jpg
wasn't crazy about all white
http://i10.photobucket.com/albums/a1...7/DSC00466.jpg
This is how I fixed those cutouts on the tach after redline. I did it with a piece of red envelope
http://i10.photobucket.com/albums/a1...7/DSC00471.jpg
