-   -   Looking for a Trailing Arm Nut Size (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/267651-looking-trailing-arm-nut-size.html)
HDBrown 02-21-2006 09:28 AM
I'm buying a 944 that is missing the Nut that retains the rear trailing arm bolt. I'm trying to find the nut size without removing the bolt so I can just thread the new nut on and drive it home. Can anyone tell me what size this nut is?
The attached picture has the nut "in question" circled in red. Thanks!
.http://forums.pelicanparts.com/uploa...1140542798.jpg
Techno Duck 02-21-2006 11:36 AM
I think im looking at the right part in PET...
N.022.131.4
Lock Nut
VM 12x1,5
HDBrown 02-21-2006 07:57 PM
Thanks for the info - can you explain?
Techno Duck,
Thanks for the info - can you explain what it means? What is "PET"? Is the "N" number the parts number? I've got the "lock nut" part, what is the final code - the metric size? Thanks again.
Techno Duck 02-21-2006 08:37 PM
Hi Hank, The top part is the part #. Lock nut came up as the part name /description...and the final part is the size and pitch i would guess, atleast thats how its usually laid out for the usual nuts and bolts i look up. I am not sure what the VM means before the actual size.
PET is the electronic parts database for the 944. You can basically look up all the technical diagrams for the 944 (or any Porsche for that matter) and find names, part numbers and sizes for any nut, bolt, screw and washer that is on a 944 (and more). It was not available to the general public up until recently...you can now get it off Porsche.Com as a .PDF file.
http://www.porsche.com/usa/accessoriesandservices/classic/classic-originalparts/originalparts-originalparts/
HDBrown 02-22-2006 02:45 AM
Thanks Techno Duck!
Thanks a lot - that is an excellent education that has a lot of future potential. I really appreciate it sir!
