armandodiaz's Avatar
WTB set of pistons for a 944S
I need to replace the rings on my 87 8 valve. The spec state the compression is 10.2:1 and the 44S is at 10.9:1.
Since I was pulling the pistons out anyway I was thinking of putting the S pistions in, if they are not too expensive. They are both 100mm. Has anyone done this, or does anyone see an issue with this?
Armando Diaz
85 911 Carrera - Track car
01 996 Carrera - For Sale http://forums.pelicanparts.com/showthread.php?s=&threadid=327823&highlight=996
87 944na - Old Daily Driver, now 944 CUP
03 Chevy Avalanche- Support Vehicle
70 Olds 442 W30 Conv- Gone but not forgotten
http://www.diazracing.com
adiaz@diazracing.com
Old 02-24-2006, 05:25 AM
Please move to parts sales
I accidentally posted on the wrong board....
sorry.
Armando Diaz
Old 02-24-2006, 06:34 AM
Team SSR's Avatar
The S pistons won't be cheaper and the valve reliefs are completely different.
Old 02-24-2006, 10:12 AM
The pistons won't work on the 8-valve head. You will bend all of your valves within 10sec of start up.
86 944 daughters
88 944 step-sons
07 Ranger 4x4
I have tons of spare parts, let me know what you need.
Old 02-25-2006, 07:46 PM
Thanks for the info. Now, I got my specs form clark's garage. But someone stated it was the wrong info. They stated 87 8valve 944s were 9.7:1 and 88s were 10.2:1. Can anyone give me the right specs?
Armando Diaz
Old 02-26-2006, 05:06 AM
Team SSR's Avatar
'87 and '88 should be the same CR. In '89 the bore size increased from 100 to 104mm and the CR increased correspondingly from 10.2 to 10.9.
Just a note: Pistons are expensive for these cars. Many rebuilds are performed and the original pistons are re-installed with new rings.
Old 02-26-2006, 08:20 AM
Thanks Team, that's what I figured. I was planning on replacing rings but thought I might have a change of giving it a bump up in compression, with a used set of pistons.
BTW:
Has anyone ever heard of the main bearings going bad or any issues with the the wrist pins or connecting rods? These will problably be the only thing that haven't been worked on and I need to do this job in a weekend. I don't have much down to offer.
Armando Diaz
Old 02-26-2006, 03:32 PM
Where ever you got that info from is correct, the '88 had higher compression.
Old 02-26-2006, 03:39 PM
This shows the 87-88 with the same 86 had 9.5
http://www.connact.com/~kgross/FAQ/944faq02.html
Armando Diaz
Old 02-26-2006, 03:46 PM
It may show that but the '88 motor is a M44-09 and they had different pistons resulting in a 10.2:1 ratio. These differ from the euro pistons also which had no dish on top, just valve reliefs.
Old 02-26-2006, 04:25 PM
even if you could use the 16v pistons with the 8v head, your compression ratio would actually go down...its the 16v head that ups the c/r
Tom
Early '85 944
Old 02-26-2006, 04:53 PM
fast924S's Avatar
Send a message via AIM to fast924S
Yes the 88 944 engine has the 10.2 CR pistons WaA420 is correct
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 02-26-2006, 07:44 PM
Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
Those specs are Euro and incorrect as I stated at CG. The 944 na in 87 is without a doubt 9.7:1 and the 88 at 10.2:1
Dal
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 02-27-2006, 03:05 AM
Dal you are correct, I opened up my old box of Porsche manuals and looked up the specs. They actually have the 87 USA with 9.5 and ROW with 10.6. In 88 they have all at 10.2.
Does anyone think this would make a big difference if I were to change to the larger compression? It's only .5 difference.
Armando Diaz
Old 02-27-2006, 04:00 AM
924Sman's Avatar
Yes going to the 88 CR will gain about 10 HP provided the rest of the engine is in spec. No need to use the 88 DME either, just install the 88's and off you go.
In my experience the 88 model can pull me slightly on the track. Small but noticable gain. PCA added weight to the 88 to counter the higher HP.
Dal
Old 02-27-2006, 04:51 AM
x3m944's Avatar
We can offer you a set of custom forged pistons in any size, compression, etc... you want for the 944/924S.
For 511.00 Shipped anywhere in the Continental USA.
Buying used pistons can be a serious gamble, please make sure they are full checked to within spec and still servicable.
We also do sleeves and stroker kits... just ask.
Do not Try to Beat the Odds unless you are sure you can survive them beating you!
http://img.photobucket.com/albums/v6...ec_Install.jpg
http://img.photobucket.com/albums/v637/x3m944/4.jpg
http://img.photobucket.com/albums/v637/x3m944/2.jpg
Old 02-28-2006, 10:02 AM
Thanks for the offers but if I can't do it cheap then I'll just use the old ones.
Armando Diaz
Old 02-28-2006, 10:05 AM
924Sman's Avatar
This much I can tell you the 88 pistons will go for over a grand for sure.
Dal
Old 02-28-2006, 11:39 AM
x3m944's Avatar
... cost is always relative to supply and demand, not to mention which company you buy from.
If get the same or better quality and reliability... I say find the best source for the parts and buy them.
Always more than one way to skin a cat...
Old 02-28-2006, 11:43 AM
Dal
That's crazy that's almost as much as what the whole car is worth (sorry for the 944 bashing, but this car has not been good to me).
Armando Diaz
Old 02-28-2006, 11:44 AM
