Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
Corbeau seat brackets
Corbeau offers two different seat brackets for Porsche applications (from 1978 til mid-90s Porsches all seem to have the same adapters); one is listed as "Harness" for $65, and the other is listed as "seatbelt" for $79. I am assuming that this refers to whether you would be using stock seatbelts or racing harnesses; well, what is the difference in the seat bracket between the two. WHat changes in the seat bracket hardware from "harness" to "seatbelt"?
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 03-01-2006, 07:57 AM
I actualy called and asked them about this because there was a pair of brackets on e-bay for cheap one time. The ones that say harness don't have the hookups for the seat belt. If you want to use your seatbelts then you have to get the ones labled that.
If it has wheels or tit's it'll give out problems.
Early 85 944
94 Katana 750
924 Parts Car
Old 03-01-2006, 08:52 AM
Rmills944's Avatar
Send a message via AIM to Rmills944 Send a message via Yahoo to Rmills944
I used the harness ones in my car with my TRS's (with no harness). They work great. I don't see how the mount matters considering in the 944 the seatbelts don't mount to the seat bracket anyway!
Ryan
'84 944 moneysucker edition (SFR, Corbeaus, etc.)
'02 Jetta TDI 280Lb/Ft 145Hp @ wheels. RC2 PP357's
Old 03-01-2006, 08:54 AM
Virginia Rocks!
VaSteve's Avatar
Exactly. The "harness" version is straight up sliders only. I put harnesses in my car so the seatbelt was removed from the factory seat and drilled through the tunnel.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Virginia Rocks!
VaSteve's Avatar
After 85.5 they do.
Old 03-01-2006, 08:55 AM
Writer/Teacher
CJFusco's Avatar
i think i might just use Tifosiman's bracket-fabrication process, but thanks for the responses
Old 03-01-2006, 01:59 PM
