PhillysMostWntd's Avatar
Send a message via AIM to PhillysMostWntd
Lindsey racing fuel lines
ok so i just got my fuel lines from lindsey racing, got injector gasket kits too, i ordered a dme temp sensor from them but sadly it did not come, i called and left a message, ill see what happens tomorrow..
ANYWAYS..
ive been lookin at these puppies and cant figure out how the hell im supposed to go about installing them, i know the stock lines will come out kinda easy (need to find a wrench that can squeeze in there) but there are like 8 different fittings that came with this i have no idea what goes where
does anyone have these lines and can offer some helpful info?? i looked all over their site and searched this forum but cant find anything.
also : greasing up injectors on reinstallation, what should i use to lube them up? i cant remember who it was, they recommended that i dip the ends into transmission fluid.
thanks guys
1984 Porsche 944 - down for the count, may be rebuilt
1999 Civic ex coupe - Turbocharged fun/Daily Driver
Old 02-28-2006, 08:28 PM
fast924S's Avatar
Send a message via AIM to fast924S
I was looking into those lines too, Looks like a big PITA to install, if your lines run to the p/s fender then you gotta remove the fender and cut/flare the lines and install the fittings. The guys at huntley are very helpful, Im sure if you drop a e-mail they can hook you up
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 02-28-2006, 10:47 PM
Rmills944's Avatar
Send a message via AIM to Rmills944 Send a message via Yahoo to Rmills944
I'm confused... I thought Huntley Racning went under about a year ago...
Ryan
'84 944 moneysucker edition (SFR, Corbeaus, etc.)
'02 Jetta TDI 280Lb/Ft 145Hp @ wheels. RC2 PP357's
Old 03-01-2006, 06:47 AM
Send a message via Yahoo to wizkid918
if its for your early car in your sig, im not sure if they will fit the same or not. i just installed mine, and like fast924s said, you just remove the skirt out of passenger side fender, cut lines, and compression fittings tie right in.. but on early cars, i think your lines are routed over by the driver side and it may be a little tricky, i know someone over on rennlist was having problems finding new lines for his early car for the same reason
Old 03-01-2006, 06:49 AM
SoCal Driver's Avatar
The 84's should have the fuel lines coming up the firewall.
85'5's have the plastic liners in the front fenders.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 03-01-2006, 09:21 AM
Send a message via AIM to Gear Dog
I got the same kit for my 86 and it was pretty easy to install. Don't forget to tie wrap the vacuum lines because those lines will chew up anything they touch.
86 944 some assembly required!
Old 03-01-2006, 12:12 PM
its for my 84.. so how am i gonna do this? should i just call up lindsey racing? damn.. it looks like i could rig it up but who knows if it will leak or not.
ive been going the last 6 months with a home depot special fix cause i ripped one line replacing the spark plugs
i decided i was tired of pushin my luck so i got the lines... now im lost.
i need help.
Old 03-01-2006, 02:35 PM
fast924S's Avatar
Whoa sorry I ment lindsay racing, Huntley Racing was on my mind and yes the did go out of business a while back
Old 03-01-2006, 02:48 PM
k im gonna go ahead and give them a call..[edit: err.. email]
ill keep you guys posted
Old 03-01-2006, 02:50 PM
Post a link that describes these lines in detail. Most after market fuel lines have swedge fittings for the steel fuel lines. Should have the correct metric for the fuel regulator and the damper.
Old 03-01-2006, 04:31 PM
Send a message via Yahoo to clinton
Just use petroleum jelly (IE Vaseline)
Visit my site www.orderdairy.com/Porsche/
Old 03-01-2006, 04:34 PM
thats the best i can find, i could take pictures and have them up either tomorrow or friday though if that would help.
Old 03-01-2006, 04:46 PM
The two fittings in the bottom center are swedge fittings. You use the tubing cutter to remove the stock ends on the steel fuel lines and attach these fittings. It's very important to leave a bit of slack in these lines AND tie them together. I've seen unbound fuel lines vibrate the damper off of the rail.
Old 03-01-2006, 06:52 PM
grim news
"Omid,
The lines we sold you are for cars where the lines come through the
shock tower/fender. Those are not going to work for you. Feel free
to return them for a full refund. "
[Edit: nvm this part]
so turns out the 1 of 3 things sent dont fit. (fuel lines)
1 of 3 does fit... sorta. (injector gaskets)
1 of 3 is on its way and hopefully no problems with it. (dme temp sensor)
im pretty dissapointed. not at lindsey racing just because having my car running is now delayed.... AGAIN
Old 03-01-2006, 10:19 PM
