Turbo coolant routing
Howdy,
Can someone who owns a 951 please check coolant-hose routing for me? There is a hose from the front of the water pump to the turbo. Where does the return hose from the turbo connect back into the system? Specifically, I am having a HELL of a time getting the thermostat on an NA 944 to open. It has the turbo WP. I want to connect the turbo WP hose to give water/air a new place to go from behiond the t-stat, but were should the other end of the hose go? Please, no more "how to bleed" instructions. Thanks much! |
clark-garage.com has a chart.
I am not sure what you are trying to accomplish by this..........
http://www.clarks-garage.com/graphic...stem-turbo.jpg ? but you should be able to use a block off plate on the waterpump....... |
