Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 924/944/968 Technical Forum
One apex at a time
Dean924s's Avatar
I was reading further up in the thread about calculating compression rates from PSI and while this can be done is a broad cense it does not work all that well due to cam timing.
Respectfully
Dean
General Car Specs & Mods
Project Megasquirt 924s
Old 06-07-2013, 09:45 AM
I totally agree about the weirdness! Its a second hand 944 whithout any id on the engine. The previous owner told me that its not its original but the look is the same. To which engine are these rates close to? Could it be a S engine with a na head ??
Old 06-07-2013, 10:06 AM
One apex at a time
Dean924s's Avatar
Look at the temp sensor on the head (for the gauge) Small one is pre 85.5 Large one is post 85.5 Not definitive but a good start. I think somewhere on Clarks garage there may be a casting number list you can look up your block number as well as the head casting number and get a better idea as to what the motor really is. I mix and match NA motor parts a lot when rebuilding. I usually take 83 bottom ends and use 89 heads and cams.
Respectfully
Dean
Old 06-07-2013, 12:37 PM
Hello Dean, thank you for your help!
Head part number: 944 105 250 6r (did not find any conclusive result, maybe from an S)
Bell Housing part number: 944 116 401 2R (seems to be from a turbo!)
The temp sensor looks small though.
Old 06-08-2013, 11:20 AM
87 944 na
1 - 150 - 155
2 - 160 - 165
3 - 155 - 160
4 - 150 - 152.5
Old 06-29-2013, 07:41 PM
AFM #725
Gawernator's Avatar
2 - 185
3 - 190
4 - 190
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 06-29-2013, 10:35 PM
tgx tgx is offline
84 na
155
165
165
165
Old 10-28-2017, 04:17 PM
