Unhappy Strange sound like a waterpump trouble
Hi, I think I have I trouble with my waterpump on my 944 N/A 86.
First of all, I can't see the level of cooling on the tank between Max and Min so the level should be very low.
I will buy tomorrow some prestone for fulling the tank. But I think this will not change the situation...
The situation is: When I start my engine, everything is okay, no strange sound, nothing, BUT after some minutes I hear a sound like "Twick twick twict twick, from the driver side. Could this can be a problem from a belts (less tension = make this strange sound) or this can only come from the waterpump?
Simon-Pierre
Redguard Porsche 944 1986
Old 03-12-2006, 06:09 PM
SoCal Driver's Avatar
A bad water pump will make a rough grinding noise. All the time. You can take off the top belt cover, reach down and wiggle the water pump pulley up and down when it's bad.
I think you have a belt problem. Could be to loose or too tight or missing a tooth.
It's a time bomb.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 03-12-2006, 08:57 PM
I see some crack between tooht on the timing belt, this is normal or this is a weakness; sign to change the belt
Old 03-12-2006, 09:46 PM
Eldorado's Avatar
change that belt and retension.
how long has it been? since the belts and the pump have been done?
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 03-12-2006, 09:51 PM
