livewirevoodoo's Avatar
Fog Light/Housing Replacement
Driver's side foglight. Looking to replace the whole unit - lens, housing wiring. I've got the new parts, took a peek under the car and it seems like the foglight housing is held in place by 4 screws.
However, at the location of 2 of the screws space is so tight I cant see any way of getting to them without either
A) teaching my 2 year old neice about righty tighty lefty loosy and letting her have a go at it, or
B) Remove the whole front clip and then remove the foglight housing.
Logic tells me I'm probably not the first person to deal with this. Any shortcuts or tips anyone could be provide would be of the utmost help. TIA.
''87 944na 85k
C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946
'94 Oldsmobile 88 Royale (winter beater)
Its not what you drive, its what drives you.
Old 03-17-2006, 04:43 AM
adrian jaye's Avatar
Re: Fog Light/Housing Replacement
mine is an s2
voodoo.
1> remove the 2 screw one either side, to remove the clear plastic cover
2> 4 screws remove (if they are locked/worn then drill em off) pull the glass unit out
3> back plastic
The fear of God is the begining of wisdom <><
NotJustPorsche
Subscribe: notjustporsche-subscribe@yahoogroups.com
Old 03-17-2006, 05:36 AM
