Virginia Rocks!
VaSteve's Avatar
Passenger side motor mount bolt removal?
How the heck do you get the 13mm bolts off the top of the passenger side motor mount?
I have every combination of wrenches, sockets, etc and couldn't figure it out with the exhaust manifold in place.
Come on guys, share the secret.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 03-28-2006, 06:15 PM
auh auh is offline
auh's Avatar
Send a message via AIM to auh
I'd use a 13mm socket, just my suggestion though
haha jk jk, good luck though
1974 914 1.8 Sold...
1984 944 my baby...more of a pain in the @$$ than takin' it with a cucumber, but I still love it. THE CAR YOU PERVS!!!!!!!!!!!!
1990 Nissan 240sx fastback aka Japanese 944
Old 03-28-2006, 06:23 PM
There is a heat shield that wraps over the mount. There are two bolts holding this shield to the crossmember. Remove the heat shield and you should be able to get a wrench on the bolts for the mount.
Old 03-28-2006, 07:17 PM
Above re heat shield, and you can have an assistant (giggle) pry the engine away from the body there to give you some more room.
'84 944 - new-to-me DD!
'83 944 - looks like ass, runs like horse - in primer.
'82 931 - roadster project - forever incomplete.
'80 924 - spouse's yellowjacket.
Some wrecks and a 924 racer.
Old 03-29-2006, 12:00 AM
To remove the bolts attaching the motor mount to the frame:
with the heat shield out of the way, and no power steering, I used an open end wrench. Half a turn, by half a turn. (later bought the new 'ratchet type box end wrenchs).
To remove the bolts attaching the motor mount to the engine block: you have to remove the exhaust headers first.
good luck,
JM
Old 03-29-2006, 03:32 AM
Virginia Rocks!
VaSteve's Avatar
Yeah, these look pretty rusty. I can't seem to get a wrench on to get the first "crack" of bolts held in place for a long time. But it was getting late and me tired.
Humans put this together. Elves and black majic are needed to take it apart.
Old 03-29-2006, 04:15 AM
monsterdog's Avatar
Might not hurt to burn some incense, and sacrifice a live chicken over the intake.
I remember swearing alot when I was doing this, thinking evil thoughts. Trying to talk in "German," helped alot, as well as purchasing some crow's feet, and lots of wobbly extentions and a u-joint. Sometimes I would look at the long, bent, misshapen concoction on the end of my 3/8inch ratchet and just laugh and laugh...
1986 944 Turbo, 88k miles, Copenhagen Blue
Old 03-29-2006, 07:44 AM
I just finished my motor mount replacement last weekend. The first big project since buying the car in the fall. Looking forward to getting it on the road. The car is an '86 with 72K and the mounts were original. They look like they were recovered from the Titanic. The battery is still out so I have not started it yet, but I am sure it will be much better.
On the passenger side I also removed a mount I believe holding a brake line. This gave a little more room. I used two wrenches and was able to get it out without much trouble. It was more fun getting the lower front bolt out which holds the air box to the engine side air intake. A closed end wrench with 1/12 of a turn at a time was the best I could come up with.
I was able to get the entire job done in one day with two hydraulic jacks holding the engine and two sissor jacks to help support the cross member and get it back up into place. A great sense of accomplishment and now I can have fun with the easier stuff on my maintenance list.
Stephen Fraser
Poland Spring, ME
1986 Guards Red 944NA
Old 03-29-2006, 03:47 PM
Virginia Rocks!
VaSteve's Avatar
Stubby wrench and a couple of whacks with the BFH got them loose....
Do the motor mounts look shot? LOL
Old 04-01-2006, 08:18 AM
