oil pressure?
What is the correct oil pressure for a 1985/5 944. One idle mine reads about 3 1/2 to 4. Anything above idle goes directly to 5 and stays there. Is that normal? Car seems to be running fine.
what weight oil are you running?
83 944....bye bye 85.5 euro spec 944, 5sp (she's gone.... ![]() 74 914...hasta LA Vista baby 87 924s....don't let the door hit ya 68 912.......see ya! |
I put in 10/40. I just checked the level and it is correct. It has the right amount of oil in it.
www.Only944.com Porsche parts, Only better, Only944 87 944 N/A 165,000 miles 84 944 Saved by God, because I could not. |
A "Bar" is equivalent to one atmosphere of pressure. (14.7 PSI, but for fast figuring I use 15). When cold, the pressure is, on an engine in good shape, 5 bar (75 PSI). At idle when warmed up, 2 Bar (30 PSI would be about right. Yours seems a bit high. Could be that the sender is faulty or beginning to fail. When they fail, they usually pag at 5 and stay there, even with the key on and the engine off.
Bob S. former owner of a 1984 silver 944 |
does the car come up to normal temp? just asking because i agree it seems high, maybe verify with a mechanical gauge.
