S2 motor in 87 944?
What other changes are needed when swapping an S2 motor into an 87 944? AFM, DME, climate control? Any pointers on where to begin looking at this?
Ned
1983 944 with S2 motor, trans, suspension and exterior -- crunched parts car
1987 944 -- soon to be 1987 944S2
Old 04-10-2006, 06:10 PM
Burn the fire.
Brando's Avatar
Climate control I wouldn't think so -- should be vacuum controlled HVAC same as the post 1985½ 944s, A/C lines for Evaporator/condensor can be used although I'm not sure if the A/C compressor mounts in the same location.
I would believe the whole package would be the DME, Intake, Exhaust, vacuum line routing. The good thing about the 1987 model is that you have alot of the wiring for "acessories" there already, which is not very different from an S2.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 04-10-2006, 06:15 PM
Where is the DME located on the late models vs the earlies?
Is the nose panel spot welded into place on an 87, or is that just the earlies?
Old 04-11-2006, 07:41 AM
winter-hater club member
nynor's Avatar
early dme is located directly under the steering column. late dme is located and passenger footwell.
"COOL PRIUS!" - Nobody Ever
Old 04-11-2006, 09:08 AM
