BEFORE YOU BUY ANYTHING, fiddle with the tire pressures. What size are the tires? Try filling the front to 33psi. It couldn't hurt.
Its normally 29 psi on the front isn't it? I thought over inflating usually reduced grip? Like you say. It can't hurt..... |
29 psi front cold/36 psi rear cold......or 2.0 bar front and 2.5 bar rear
Dal |
Hmmm, it weird - today rather than comedy understeer at ridiculously low speeds it was comedy oversteer! Presumably just the effect of dry weather. You don't have to be going quickly to provoke it - hmmm, with that in mind, may be I won't replace the bushes afterall :)
(Only joking...) |
dry weather? Wouldn't you get more oversteer on WET roads?!?
Hmmm 195 tires? That seems rather narrow for a 944... |
195 is stock on a 924S
