Eldorado's Avatar
throttle cable
the throttle cable. I see that mine is worn.
does it, at rest, put tension on the pulley at the top of the throttle body? If i remove the cable, the pulley stops in the same place. my cable is letting it rest in it's most counter-clockwise position.
when you turn it clockwise by hand, you can hear a click within the first few degrees of turning it.. it rests just beyond this click (beyond meaning in a counter-clickwise postition.)
is this too far? or is it normal?
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 04-13-2006, 09:56 AM
I think the click you are hearing is the throttle position switch. The switch position is adjustable and you want it to click just as the throttle is closed. I adjust my throttle cable to make sure that it will fully open the throttle with the pedal down. Then I check to see that the throttle fully closes when the pedal is up. There is usually a little bit of slack with the throttle closed. Do not use the throttle cable adjustment to match the throttle position to the switch - use the switch adjustment for this. The switch is held onto the throttle body with two screws. Loosen them to position the switch.
Old 04-13-2006, 01:16 PM
Eldorado's Avatar
great
so as the throttle is being let out... *just* as it's about to close all the way, you're supposed to hear the click?
Kyle
Old 04-13-2006, 01:23 PM
Yes
Old 04-13-2006, 06:10 PM
