968 Check engine code 1223
My 1992 968 has a check engine light that comes and goes. code is 1223 that is "Oxygen regulator
Anyone got any ideas what this means and where to start diagnosing this issue ? Stephen:confused: |
Not a solution, but this thread might provide a hint: http://65.61.16.109/forum/topic.asp?TOPIC_ID=8963.
Personally, I'd re-ask the question over on 968.net or 968forums since blink codes are particular to the 968 (not on any other 944-variants). Good luck.... |
O2 Sensor Mebbe? Perhaps the computer is getting a faulty reading from the MAF? What are the symptoms? I second 968forums.com, there is a good sized VERY active 968 community there. If you are in SoCal, some folks may help you figure it out and fix it for the mere cost of a few top shelf brewskis.
Micah |
| All times are GMT -8. The time now is 02:22 PM. |
