Learning through mistakes...
Rebuilding a 1983 944 (my first). Removed the transmission to get to the fuel tank (needed repair). When I separated the drive shaft at the coupler, I failed to mark the coupler on both sides. Of course when the transmission separated, the coupler stayed on the side I marked (transmission side) and pulled off the drive shaft. I haven't turned the drive shaft and can guess at the position because the head of the bolt in the coupler was visible in the cutout in the transmission housing. Is there any way to recover the alignment if you have not marked the shaft?
'83 944
'87 951
Old 04-21-2006, 08:05 AM
I don't think it matters
89 944 na Dove Blue Metalic
2000 chevy silverado
2000 chevy 454 dually black
79 GMC short bed 4x4
4 quarter horses
89 acura legend GS sedan
Old 04-21-2006, 12:37 PM
arbita1's Avatar
In write ups I've seen, it says to mark them so you can put them back the same way. I don't know why. Maybe so it continues to wear the same way?
When I replaced my transmission, I lost my markings. So I just put it back in. Didn't seem to matter.
Matt.
83 911SC
85.5 944 NA - Sold
Old 04-21-2006, 01:07 PM
Granite 944's Avatar
Its a coupler. Don't worry, be happy. Worse things can and will occur. Grease it up prior to re-assembly. If you don't have things lined up properly on install, you won't be able to get it back together. You'll see.
1985/1 944 Granite Red (wife's car. Iceshark is lighting her way)
1983 944 Platinum (my daily)
1985/1 Guards Red (project)
Old 04-21-2006, 04:50 PM
Burn the fire.
Brando's Avatar
Doesn't really matter... When I dropped my trans for a clutch replacement it went together fine. No excess vibrations or wobbling at the connection back there. You'll notice that it has been drilled and balanced, so I don't think it matters exactly how it goes back on.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 04-21-2006, 05:46 PM
