-   -   944 Engine Rebuild Status Update - PICTURES (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/278940-944-engine-rebuild-status-update-pictures.html)
cchyper 05-13-2006 03:38 AM
AE1969!!!! thank you for the answer. I will now buy 10AN adapters for the oil cooling system.
cchyper 05-13-2006 10:05 PM
Progress Continues
This engine build is really starting to show some color. I am proud to announce that we have made more progress. Here are the picks from todays work, i really think it is looking nice.
ENJOY!
I took a lot of pictures I am only posting a select few on pelican, please see my blog with all the pictures and descriptions/instructions on procedures.
P O R S C HE - 9 4 4 Project Blog
http://photos1.blogger.com/blogger/4...DSCF0005.1.jpg
http://photos1.blogger.com/blogger/4...DSCF0007.0.jpg
http://photos1.blogger.com/blogger/4...DSCF0014.4.jpg
http://photos1.blogger.com/blogger/4...4/DSCF0011.jpg
http://photos1.blogger.com/blogger/4...4/DSCF0019.jpg
http://photos1.blogger.com/blogger/4...DSCF0024.0.jpg
http://photos1.blogger.com/blogger/4...DSCF0028.1.jpg
http://photos1.blogger.com/blogger/4...DSCF0040.3.jpg
http://photos1.blogger.com/blogger/4...DSCF0030.5.jpg
http://photos1.blogger.com/blogger/4...DSCF0037.3.jpg
Usmellgass2? 05-14-2006 10:27 AM
Nice very very nice. One question though; all the head and bottom end studs that I have installed, the manufacture has specified that the studs are NOT bottomed out in the hole. it looks like you are installing them tight against the bottom of the hole in the pics. I really think you should be absolutely certain this is a correct installation. Just tryin to help out, let me know what you find out please.
cchyper 05-14-2006 12:16 PM
Thanks for the advice. We were only going off of the stud height from the deck (73mm). I will have to look into it in more depth.
WaA420 05-14-2006 12:55 PM
Dave,
None of the studs actually bottomed out but were a little tight towards the bottom. We were using the 73mm figure the manufacturer provided.
Usmellgass2? 05-14-2006 01:01 PM
Sounds good. I saw the pic with the double nut and it raised a red flag. I cant wait for start up!
NKN84944 05-14-2006 02:41 PM
Holy smokes that looks terrific!Definitely enjoying watching this engine porn http://www.pelicanparts.com/support/smileys/wat6.gif
cchyper 05-14-2006 04:30 PM
THANKS GUYS! i am happy to see some excitement - CAUSE I AM MORE THAN READY FOR THE KEY TURN.... BOOM! hahahhaha..
This is month 5 of the rebuild - talk about slackers!
I was watching trucks today and the dudes got a full header back 2.5 in mandrel bent exhaust system made for a chevy 350 (minus cat and muffler) for a total of $245!.... does anyone know of a person who can make one for my porsche for that cheap!!
JimboDean 05-14-2006 05:03 PM
Wow, love the red powder coated parts cchyper. Wasn't your first choice Magenta? I can see the Powder Coating shop running out of such a high in demand color. Anytime the word "porsche" is mentioned, expect prices for exhaust to double. Now unless you tell them it's for a 2.5 liter Chevy.....perhaps the ol Citation II.
<img border="1" src="http://files.conceptcarz.com/img/chevrolet/chevy_citation_iv_01.jpg">
cchyper 05-15-2006 02:49 PM
HAHAHAHHAHHAHA HAHAHAH AHA HAHHA.....
Bose You Are GOOD.
DOUBLE so far .... i hear TRIPLE!
WaA420 05-15-2006 08:00 PM
When you get the motor all done are you going to put it in that citation. I used to have one with a 2.5l and it was fast and got me more a$$ than a toilet seat. Chicks dig citations, but so do wankers.
TheCooler 05-15-2006 08:06 PM
Nice engine!
AA_Ezra 05-15-2006 10:32 PM
Very Nice Love the powder coating, Stil looking for a electric oven cheap so i can try it myself. On the Intake manifold, Was that bead blasted because the inside looks CLEAN as do the flat surfaces.
I guess the shop Honed and re-etched the block correctly as you didnt post that they made a mistake there. Or did i miss something?
Usmellgass2? 05-16-2006 06:51 AM
I might be able to help out with your exhaust. PM sent
ronin 05-18-2006 02:24 PM
hyper, good to hear from you this morning. thanks for the call. let me know how things go with the oil cooler. stop by sometime and check out the shop
Usmellgass2? 05-18-2006 06:31 PM
Are you using a 951 oil cooler housing to tap a remote cooler? I want to run a oil cooler but am not sure that the spacer under the filter is the way to go.
cchyper 05-18-2006 07:16 PM
Yes, I am using the factory 951 oil cooler housing to eliminate that dangerous and rather ineffecient factory oil to water cooler. I went to a hydraulic fitting store today to get all the right fitting sizes (below). I will be using a after market $100-$130 10-12 row aluminum cooler w/ 10AN connectors (factory 951 is a $600 7 row) off of ebay or summit racing with stainless lines and adapter fittings (aluminium is not as ACCESSIBLE, cheap or strong). Each adapter is going to run about $20 plus $7 a ft for the stainless line. It is not necessary however to use the stainless line, for the pressure is not that great (but it looks cool and wont breakdown easy).
Fittings for a 951 oil cooler:
Feed and return line: M24x1.5 female x M#10AN
Seattle Area Helpful Contacts Include:
- Fittings Inc. on 4th and Michigan, South Seattle. 206.767.4670
- Williams Oil Filter Service Tacoma
cchyper 05-22-2006 07:15 PM
Cage install:
Mounting
http://photos1.blogger.com/blogger/4...DSCF0011.0.jpg
Looking Crappy! Before paint
http://photos1.blogger.com/blogger/4...DSCF0002.6.jpg
Looking Good! After Paint
http://photos1.blogger.com/blogger/4...DSCF0008.2.jpg
Usmellgass2? 05-22-2006 07:44 PM
Is that a auto power bar? Cool stuff! Could you do me a big fav and post detail about swaping the 944 oil cooler for the 951 setup? I want to do the same deal, get better oil cooling and not have the oil heat load the liquid cooling. If its better to put it on your blog I check that often too.
GL
Dave
cchyper 05-22-2006 07:51 PM
Gracias senior... i will do a detailed write up about the oil cooler install... i am just now getting all the parts to complete the project. Its all coming to gether tho... i just got the new late deep oil pan in the mail today... YEEPPY!
never thought i would be so excited to see a oil pan
chris
