Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
chapstic2001's Avatar
Send a message via AIM to chapstic2001
Oil Pan Bolt Specs.
Can anyone tell me the part number or specs for the oil pan bolts. I thought I read that there were different lengths, depending on which hole they occupy. So for clairification I am talking about the drivers' side rear bolt. If that is not the case, please let me know.
I was under there yesterday and noticed that 5 of the rear bolts were getting a full turn before even hitting the 3-ft/lb torque mark and one was missing compeltely. Explains some of my leaks.
Any assistance is appreciated.
For the record, this is for a 944 Turbo 1986.
http://www.eastcoastallstar.com
http://www.illegalstreetracing.tv
'86 951 (K&N Cone, Welt Chips, Tial, Zeitronix, P&P O-ring PH Head, WFHG, AFPR)
'99 B5 Passat 1.8t (Bone Stock)
'07 Trailblazer
Old 05-01-2006, 11:47 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
you can go to www.clarks-garage.com it can help you. but heres what it says
Install the pan onto the crankcase using the mounting bolts but, do no fully tighten the bolts. Once all the bolts are installed tighten them using the torque specs and sequence shown below:
Step 1 - Install bolts
Step 2 - 4 Nm (3 ft-lbs)
Step 3 - 8 Nm (6 ft-lbs)
86 Red 944
85.5 Red 944(sold)
Old 05-01-2006, 12:02 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
The torque specs are not the problem. I need the specs on the missing bolt, i.e. length, thread count etc.., so I can get my hands a new one.
'07 Trailblazer
Old 05-01-2006, 12:10 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
Virginia Rocks!
VaSteve's Avatar
Use the PET or when I get home I can measure it. I have them all (from both engines) sitting on my workbench. I think it's a 6mm (M6) bolt.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 05-01-2006, 12:22 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
You lost me at PT. What is that? I was going to swing by Curry's or Dulles Int'l Motor Sport(two local Porsche Shops), but I want to make sure I get the rigth lenght and thread pitch.
Let me know what you find out Steve.
'07 Trailblazer
Old 05-01-2006, 12:26 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
Virginia Rocks!
VaSteve's Avatar
The PET. Sorry for the mistype. The long ones are M6 x 50 (900 075 344 02) The short ones are M6 x 25 (900 075 341 02).
Now I don't need to do it at home
Old 05-01-2006, 12:36 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
89 944 S2
Does anyone know how many long or how many short I need?
Old 04-23-2012, 02:28 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #7 (permalink)
I think there's only four long ones, lemmi go check the pan on my spare block..
"porsche it's an institution"
Old 04-23-2012, 06:28 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #8 (permalink)
89 944 S2
Thanks cauzomb
Old 04-23-2012, 06:40 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #9 (permalink)
There are 4 M6x50 and 18 M6x25 bolts that hold the oil pan on.
Old 04-23-2012, 07:15 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #10 (permalink)
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
and 22 washers
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 04-23-2012, 09:03 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #11 (permalink)
lota new washers
Good luck mang.
Old 05-04-2012, 08:32 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #12 (permalink)
RedBaron's Avatar
FWIW I had to torque the gasket at stage 1 several times because it kept compressing. I have no leaks now. When you are finally done, come back in a few hours and just double check them.
1989 Porsche 944S2 Guards Red
Old 05-05-2012, 08:59 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #13 (permalink)
89 944 S2
I got the washers and bolts, and installed. There were a total of three missing, two under the oil pressure sending unit bracket. All is well!! Thanks
PS....do these have a habit of coming loose?
Old 05-06-2012, 09:27 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #14 (permalink)
Bolts have a way of getting loose at just the wrong time. There may be something going on with the engine, either hot/cold extremes, or rough running/excessive vibration leading to loose/lost bolts, either that or a rushed mechanic not waiting between torque sequence, to allow for the pan gasket to "squish down"
Red-baron has the right idea.
I remember putting my pan gasket on cold in the morning and having to wait between 20-30 minutes between torque sequences to allow the gasket to "squish into place" before the little bolts bottomed out on the gasket's metal sleeves on the final torque.
Old 05-06-2012, 11:21 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #15 (permalink)
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
