how tight?
I've got two torque settings in my manual for the oil drain plug, one at 36ft/lb the other at 43. I need to get this right as my s2 has a plastic sump. Can someone tell me the correct figure please? It may be completely different from those mentioned.
944s2 |
Non Compos Mentis
Try 36 and check for leaks.
Greasy Member
I have used 36 on many of the S2 plastic sumps with no leaking.
Good luck -Nick
Owner: Bennington Motorsports www.benms.com Sponsor for Midwest Region 944-SPEC racing series -When was your timing belt changed or tensioned?? -Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP. |
Many thanx
944s2 |
winter-hater club member
um... someone explain this to me: the sump is PLASTIC?!?
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
