Virginia Rocks!
VaSteve's Avatar
Poor oil pan gasket install?
What the hell happened here? I tied this in place, I torqued it to spec, but it looks like it went awry. I didn't notice the problem until I installed the flywheel. I suppose this is not ideal, correct?
Should I pull it off and try it again? I guess better on the stand than when in the car and buttoned up.
I'm beginning to hate this car.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 05-04-2006, 06:30 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
Steve, I'm guessing you are looking at the gasket sticking out further on the corners. I think it will seal okay.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 05-04-2006, 08:23 PM
Virginia Rocks!
VaSteve's Avatar
Yeah it's just touching the flywheel (slightly). Certainly it will rub off in a couple of minutes, but would rather not find out it's a problem when its back in the car.
Old 05-04-2006, 08:25 PM
If you are worried, take a scalpel or retractor knife and cut the excess on the outside away. I don't think I would be concerned at all.
Tom
Old 05-04-2006, 08:36 PM
I have found that it takes about 5 or six passes on the bolts when tightening the pan. Start at the middle and make two passes just finger tightening. Then make a couple of more passes with light pressure on the ratchet and wrench. Finally torque. If you try to use fewer passes, my experience has been that the gasket gets pushed out on the corners as your photo shows. Much easier on a stand with the engine inverted. Then you don't have to worry with the dental floss.
Old 05-04-2006, 08:40 PM
Striped out one or more bolts on mine, First time it squeesed out all over the place and i didnt use any sealant i just plain put the gasket on. If only i had known i was suposed to put sealant, Hayens if i recall didnt say to do it. Oh well :/
Jaime O.
Thank god I crashed or i would never have owned a porsche
83 944 daily driver (clutch and tt time)
85 325e BMW T-boned R.I.P.
Old 05-04-2006, 11:23 PM
aribop's Avatar
Oil pan gaskets are supposed to go on dry except for sealant in the corners where it goes around the oil pump and the rear main.
Steven makes and sells oil pan gasket retainers that keep the gasket from bulging out. I will never replace another oil pan gasket without using these retainers. I do not have a picture handy but you can reach Steven here: steven.wistuba@ypg.com.
'95 993 Monster in the making
'89 S2/Turbo aluminum grill monster: terrorizing another state
Old 05-05-2006, 07:59 AM
Virginia Rocks!
VaSteve's Avatar
I just took this photo to a shop when I was dropping off my injectors. He said it is supposed to go on dry and the RTV makes it too slipperly. So I'll be doing it over.
Old 05-05-2006, 10:47 AM
If you are going to do it over..probably best to use the procedure jwade outlined. You will probably get a little better results.
Tom
Old 05-05-2006, 11:50 AM
Yes, the sealant allows the gasket to slide. It should go on dry, except as previously stated, on the corners. If you pull it and clean the gasket off you should be ok.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 05-05-2006, 05:27 PM
Virginia Rocks!
VaSteve's Avatar
I'll give that a shot.
I'm not sure what you all mean by the corners. That was the corners!
Old 05-05-2006, 05:58 PM
