1984 porsche 944 non turbo
just bought a 1984 porsche 944 when i turn the key it turns over but it wont start ,sounds like the battery is almost dead but its new. any advice?
It didn't start when you bought it? Or it will not start now?
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Two things you need are spark and fuel. I would check to see if you are getting spark first then I would check to see if you have enough fuel pressure. If you have both of those then you will have to start checking sensors to make sure they are working. Their could be any number of things making the car not start but that is the order that I would start in.
86 Red 944(sold) 85.5 Red 944(sold) |
this is what happened
had the car sitting for a while a mouse got under the hood and chewed up some wires and vaccum hoses
Guess you have to replace/repair what the mouse chewed up. Take pictures of the damage and post them.
