-   -   idle surging (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/283023-idle-surging.html)
porwanabe 05-17-2006 02:11 PM
I just got the cleaner and will be trying to clean all plugs etc that i can find.
Once that has happened, I will check the readings as detailed in CG.
I will get back.
thanks
porwanabe 05-17-2006 06:25 PM
My question still stands. Why does this happen only when the engine gets to temp. does not occur when cold.
olerebel 12-05-2006 09:08 AM
What is the part number for the TPS... I am having a difficult time finding it
SoCal Driver 12-05-2006 09:22 AM
In many cases you can take the TPS apart and clean it. Don't need to by a new one.
nynor 12-05-2006 11:35 AM
when it gets hot, the connections seperate, due to bad solder or what have you.
