Heater Core problems in my 944
My heater core is leaking like crazy in my 84 944.....I really don't have the time to take the core out....can I bypass the heater core somehow until I have the time to do a proper repair....
Old 05-23-2006, 02:42 PM
SoCal Driver's Avatar
Yes. Look at the back of the block. Need a bit of hose that will come off the end of the long piece of tubing then to the valve. Can't recall what size.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 05-23-2006, 04:06 PM
Granite 944's Avatar
Like SoCal said, just remove hose from heater control valve, and put a hose between the rear of head feeder nipple, and the tube running along the bottom of cam tower. That will bypass the heater core. Yep, it IS fun getting to, and replacing that heater core. BTDT. Make no mistake. Replace both hoses that go into and outta that core, at the same time. Buy brand new core. You really don't wanna do this twice.
1985/1 944 Granite Red (wife's car. Iceshark is lighting her way)
1983 944 Platinum (my daily)
1985/1 Guards Red (project)
Old 05-23-2006, 05:50 PM
Thanks guys.....
Old 05-23-2006, 06:49 PM
