fuel pump question
Got tons of useful info from this forum...thanks all.
Now have a question of my own. Have an '84 944. Noticed fuel pump growling so decided to change it before it stranded me. Replace with new (not rebuilt), and still have same noise...maybe even a bit worse. Any ideas?
Thanks,
Scott!
Old 06-02-2006, 10:25 AM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
Did you change the fuel filter at the same time...and did you have a good flow from the tank?
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 06-02-2006, 11:01 AM
yes to both...that is why I am so confused...
Old 06-02-2006, 11:04 AM
SoCal Driver's Avatar
Check your entire return line to see if it's crushed somewhere. Sounds like the pump has a lot of back pressure.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-02-2006, 01:56 PM
