reverse lights and turn signals
heres the deal. neither work.
TURNS and REVERSE. hazard lights DO work though. when i hit the turn switch the light on the dash lights solid and the exterior lights do NOTHING. and the reverse lights also do NOTHING. any help would be great. is this a common problem? maybe a relay and/or some wiring that i should start out with? thanks in advance for the help |
What year?
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
1985 (early half)
87 951, K27/6, Almond Beige, 17" Turbotwist 87 944S, alpine white, 5sp died a violent death 84 944, silver/brown, auto, gone but not forgotten "may the force be with you" |
Besides the fuses and the bulbs:
Reverse switch is on the trans. May have come loose. Think automatics reverse light switch is at the selector lever. Turn signal switch assembly on the steering column. Switch itself or even the wiring to it including the plug.
