I think its time to upgrade
I've done a lot of thinking and it is most definitly time for me to make the jump to a 951. I just have some questiongs about it before I buy...
1. How many problems does it share with the NA? ie #2 bearing 2. Is the life of the timing belt the same as an NA? 3. Life of water pump aswell 4. Can you put a 968 6 speed trans in without major modifications? I'm sure I know a lot more but I had a long night of being excited on my decision so I'm not running on that much sleep right now. Thanks Adam |
1. Dont know
2. Yes 3. Yes 4. Dont know |
obviously with all the plumbing and extra vac lines there's more to go wrong, and vac problems will be more serious.
The 968 trans will fit without too much work i think, but you will have to do something about the speed sensor, which isn't present on that transmission. 968s run the speedo off the abs. |
| All times are GMT -8. The time now is 02:31 AM. |
