-   -   removed a/c what size belt do i need?? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/286785-removed-c-what-size-belt-do-i-need.html)
jcross 06-05-2006 08:52 PM
remove a/c compressor,what size belt do i need to run without it. 1984 944 non turbo?
SoCal Driver 06-05-2006 09:02 PM
How are you going to tension the belt?
jcross 06-05-2006 09:03 PM
not sure,what do i need to do
SoCal Driver 06-05-2006 09:05 PM
You have to get an A/C delete bracket. The alternator does not tension the belt on the combo bracket.
jcross 06-05-2006 09:41 PM
would it just be better to buy a used compressor?
SoCal Driver 06-05-2006 10:38 PM
About the same cost -- $150. If you can find a delete bracket.
