remove dme?
read clarks.. it says to "release the clip on the cable end of the plug and swing the connector up and out of the way" or something like that...
I stuffed my 215lb body into the drivers footwell, looked around, and couldn't figure it out.... any hints? |
just did it yesterday
I was able to do it yesterday.... When under the steering wheel on your back looking up, the left hand side has a small black clip (the end where the wires connect to the connector. Push that clip away from the connector, and pull out the connector. Note that the connector swings and does not come out straight... it will swing toward the far end of the connector, which is attached to a screwed in mount.
Hope that helps! |
so the pivot point of the connector is the side closest to the driver's door? seems easy enough.. thanks for the tip..
got it out.. thanks for the tip..
the clip in my car was silver though... but i found it. |
| All times are GMT -8. The time now is 04:25 PM. |
