TNT25169's Avatar
Send a message via AIM to TNT25169
Adjustable camber plates and strut brace
I'm installing adjustable camber plates on my car so I can set more negative camber when racing but I also have a strut tower brace that I had on my car before I decided to make this change. Now that I no longer have the rubber upper strut mounts, is a strut brace going to make any difference in stiffening the front end and keeping things where they belong during hard cornering?
-1988 Black 944 w/ yellow koni's, coilovers with 250lb springs, adjustable camber plates, strut tower brace, weltmeister front and rear sway bars, 968 caster blocks and 5 pt harnesses
www.apartabove.com
Old 06-13-2006, 09:11 AM
cold starter
JustinL's Avatar
The strut brace should do the same job as it was doing before. The upper strut mount is a rubber peice that is bolted to the same holes that the strut mount attaches to, so the strut mount essentially keeps the towers where they are supposed to be relative to eachother. The rubber mount bolts into said tower and is unaffected by the brace. The only tricky spot you might have is adjusting camber depending on the style of strut brace you have.
The effect of the brace is still debateable but it sure looks cool (I have a KLA brace and ground control plates).
Justin
88 Turbo S Silver rose: Megasquirted fuel, assorted suspension upgrades, etc.
89 944 S2 with 968 engine: Race car
87 944: Chump car build in progress
Old 06-13-2006, 09:31 AM
TNT25169's Avatar
it's a KLA brace and I think adjusting the camber will be easy enough but I have no plans of touching the caster bolts because they are a PITA. Thanks.
www.apartabove.com
Old 06-13-2006, 09:40 AM
