my dad just took the cover off and said that the timing belt looks new. the car was well maintained.. i think they just gave up on it cause of the no spark problem... i kinda only figured it out by luck i think...
now to tackle the other small electrical problems and the dang sunroof..... |
Don't ever trust the looks of the timing belt. Change it so you KNOW that is it new. I wouldn't even trust a reciept for a new belt.
Should/when the timing belt breaks you will be pumping from $900 to $1500 into it to replace the bent valves and maybe a pistion or two. |
| All times are GMT -8. The time now is 05:29 PM. |
