TSNAPCRACKLEPOP's Avatar
power steering adjuster
mine broke, and i had a nut welded on the end of the left hand threaded rod. i need a new left handed locknut, since mine was alllllllll vice gripp rounded off by the p.o.
has anyone just made an ajustable bracket to replace this piece of overengineering turnbuckle apparatti??
thanks
tom
chance favors the prepared mind
1987 944 n/a 5spd. who remembers dial phones?.
'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE"
Old 06-16-2006, 09:02 AM
well, if anyone gets an extra one for fathers day, let me know.
thx
tom
Old 06-17-2006, 02:36 PM
That Guy
Techno Duck's Avatar
Remove both the eyebolts and coat the threads with antiseize.. you will never have the problem again.
I ran into the same problem and broke the alternator turn buckle.. was lucky the guy next door knew how to weld well enough to tack the eyebolt back together.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 06-17-2006, 03:23 PM
these damn things are notorious for breaking, i had a welded one also (from the p/o), and it still broke. The high volume four cylinder has so much vibration, the p/s and ac adjustors just break...i think there should be a third compensating shaft . but anyways, I wanted to make my own thing cuz i didn't want to spend the $50 or whatever, but even going online to mcmaster, buying one was the cheapest way to go...
Old 06-18-2006, 02:14 PM
thx for the antisieze idea!! i think the p.o. just couldn't figure it out laying upsidedown and backwards tightening the belt.
i will use my old one, and begin fabricating new ones. i did not think that the a/c one would break since it is so large, but the stresses are great with that type setup, and part of this agony is fixing the a/c when i get her back together.
thx all!! tom
Old 06-20-2006, 04:50 PM
That Guy
To tell you the truth, i get confused with which way to spin the lock nut when i want to loosen them...and thats with the car on a lift. I always figure its one of those crazy reverse threaded things....you never know with these crazy German engineers.
Jon
Old 06-20-2006, 05:24 PM
